March 08, 2026, 10:12:48 PM *
Author Topic: wires  (Read 1997 times)
art
Grants Pass,Or
Grants Pass,Or
« on: April 24, 2009, 03:27:10 PM »
anyone know where I can get a new set of spark plug wires for my 2002 valk an how much do they cost.Art in Oregon
« Reply #1 on: April 24, 2009, 03:50:34 PM »
You have a couple of choices.
Order the EOM wires from your dealer or Honda Direct Line.
Other option:
Go to your Parts store, pick up the color of wire you want if it isn't black and make em to order....
It isn't all that hard to do.......
Patience, easy going, a can of WD40 and some shop towels....
« Reply #2 on: April 24, 2009, 05:52:08 PM »
Check the link to Shop Talk. Shows how to change out your plug wires with whatever color you want as RJ suggested, and retain your OEM plug caps.
http://www.valkyrieriders.com/ShopTalk/plugwires.pdf
Master Blaster
Deridder, Louisiana
« Reply #3 on: April 24, 2009, 06:01:57 PM »
Master Blaster
Deridder, Louisiana
« Reply #4 on: April 24, 2009, 06:15:30 PM »
The Valk wires are stranded core, and have a resistor in the boot.  Ive never seen a set go bad, and would be surprised if yours need changing.  The set above are resistor wires that I installed in the stock boots after removing the resistor and wire.  Only reason was to match the astetics of the bike and also I just wanted to try it.  It came out pretty good and the yellow goes with the flames.
art
Grants Pass,Or
Grants Pass,Or
« Reply #5 on: April 24, 2009, 08:49:44 PM »
I did replace the wires with the yellow ones correctly an now the valk. is running terrible.I did a post about miss firing a week ago.I de smoged changed the plugs an wires an balanced the carbs . I adjusted the valves an It still runs lousey.I guess i am going to have to bring it in to the shop an have it worked on I give up.It seams that I have met the enemy an I lost .
