September 18, 2025, 12:31:56 AM *
Author Topic: Interstate and Standard seat interchangeability...  (Read 1416 times)
Jabba
VRCCDS0197
Greenwood Indiana
« on: August 01, 2011, 10:07:38 AM »
OK, as many of you know, I have a Standard AND an Interstate.
After my roundabout route to IZ-XI and a desire to do more long distance riding, I am considering a Russell Day-Long saddle.
Here is my question... I'd like to have a 2-piece saddle for both me, and my wife.  My IS seat is a 1-piece.  But I'd like to be able to use the drivers saddle solo on the standard too.
Will this work?  What would I have to do to make it all work?
I THINK that all I should have to do is find a used, 2 piece standard or tourer seat set to use as a seat pan, and have them make it for the IS.  Then, use the drivers saddle on my Standard when I desire to do so.
Can anyone comment?  I called Russell and they didn't seem to be SURE.
Thanks!
Jabba
Chattanooga Mark
« Reply #1 on: August 01, 2011, 11:12:53 AM »
Pretty suer the Interstate tank is a bit longer so unless your Standard has an Interstate tank, they won't be interchangeable.
Mark
(Flat Tax advocate, first to your last dollar, all at the same rate. That way everyone is a tax payer and equal in their percentage contribution.)
www.bikersforchrist.org
Red Diamond
Beaumont, Texas
« Reply #2 on: August 01, 2011, 11:18:39 AM »
I have a Tourer/Standard seat on my Interstate. The fact that it rest against the tank a bit does not bother me. I also have a Tourer/Standard seat on my Tourer, not swapping seats.
Pete
« Reply #3 on: August 01, 2011, 11:31:14 AM »
I swap 2 piece standard and a IS seat back and forth on my IS all the time. Look fine, works fine.
As mentioned a IS seat on an Standard does cause the front of the seat to intrude on the gas tank.
You may or may not like the look of that.
Have fun.
« Reply #4 on: August 01, 2011, 11:33:23 AM »
I don't think the Interstate tank is any longer.....it's taller/fatter at the seat end of the tank.  Not sure if your plan would work (thinking not), but you might could consider putting an I/S tank of your tourer and then seat compatability wouldn't be a problem for either one of your Valks.
Red Diamond
Beaumont, Texas
« Reply #5 on: August 01, 2011, 11:51:29 AM »
Have fun.
If thnk you mean, the Standard seat intrude on the tank of an Interstate. The I/S seat leaves a gap at the tank of a Standard.
BradValk48237
Oak Park, MI
« Reply #6 on: August 01, 2011, 12:34:35 PM »
JAbba,
 Pop the key in and plunk down the standard seat you have.... might need a little push, but it should go and will touch the tank. I have been using a modified Standard seat on my I/S Super Valk for a year. I used to switch it out with the I/S for long trips, but now I just leave it. Gives me more room for a cooler instead of a passenger. The rear pad should bolt on regular also. The mounts are the same. I don't use the pillion pad because I have a Utopia Back rest and seat rail and its to much of a pain to unbolt it all to put on the I/S seat with the Utopia mount.
B
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #7 on: August 01, 2011, 12:39:30 PM »
That's what I was looking for.
I ride the STD one up a lot more often. But the IS probably more miles. I sure would like to be able to use my potential new $700 saddle on both.
Jabba
X Ring
VRCC #27389, VRCCDS #204
« Reply #8 on: August 01, 2011, 12:51:41 PM »
This might help you Jabba
Standard/Tourer Seat on an I/S
I/S Seat on a Tourer
Marty
MP
North Dakota
« Reply #9 on: August 01, 2011, 04:22:53 PM »
But, a Day long does not go up and over the tank as much, so i believe it is less of an issue than an Ultimate, which goes over the tank a little.
MP
"Ridin' with Cycho"
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #10 on: August 01, 2011, 05:39:27 PM »
I think it'll be OK.  My stock STD seat goen onto my IS without issue.
I'll be looking for a duplicate set of stock seats to carve into russells.
Jabba
Dave Weaver
Seymour, IN
« Reply #11 on: August 01, 2011, 06:44:31 PM »
I have a stock seat you can have.
Do unto others as you would have them do unto you.
Nickster
My Baby
« Reply #12 on: August 01, 2011, 07:52:31 PM »
I have a 98 tourer with an Interstate tank.  I run a two piece seat that came off a 98 standard.  Yeah thats right a 98 standard.  Been down the Alaska/Canadian Highway three times and wouldnt trade that seat for the world.  HAHAHAHAHA
Good Luck JABA
AkNickster
Aknickster
