February 03, 2026, 03:50:20 AM
Wheel weights
Topic: Wheel weights (Read 1776 times)
BIG--T
The Twilight Zone
Wheel weights
August 02, 2011, 09:38:19 AM »
My wheel weights which look factory are literally becoming unglued! They are not off but have moved and is a black adhesive under them. It's not vibrating yet but have never seen weights glued!
Daniel Meyer
The State of confusion.
Re: Wheel weights
August 02, 2011, 09:56:21 AM »
The oem weights clip on the center ridge on the rim. No glue/tape used.
Some aftermarket weights are lead strips that tape to the rim with double-sided tape.
CUAgain,
Daniel Meyer
TomE
Re: Wheel weights
August 02, 2011, 10:01:24 AM »
Glue them back on before they fly off.
They can be off a half inch or so without any noticable issues.
BIG--T
The Twilight Zone
Re: Wheel weights
August 02, 2011, 10:24:34 AM »
Daniel every bike I've owned always clipped on at the rim. Like Tom said I better glue them back on before I lose them! Gorilla glue??
Farther
Quimper Peninsula, WA
Re: Wheel weights
August 02, 2011, 01:13:40 PM »
Put Ride-On in the tire and forget about the weights.
~Farther
Re: Wheel weights
August 02, 2011, 02:00:39 PM »
Pull off the old weights and go with the Dyna Beads. Liking the beads with my d/s choice and the metz up front. It be wurkin fer me.
RIDE SAFE.
BIG--T
The Twilight Zone
Re: Wheel weights
Reply #6 on:
August 02, 2011, 03:12:46 PM »
Quote from: Farther on August 02, 2011, 01:13:40 PM
I never heard of it and did a search and it sounds almost too good to be true! You just put it in the tire and it also coats the tire to prevent puntures. Where did you get yours?
Farther
Re: Wheel weights
Reply #7 on:
August 02, 2011, 03:19:50 PM »
Quote from: XGUY on August 02, 2011, 03:12:46 PM
Where did you get yours? Thanks
ebay
~Farther
BIG--T
The Twilight Zone
Re: Wheel weights
Reply #8 on:
August 02, 2011, 03:32:47 PM »
Quote from: Farther on August 02, 2011, 03:19:50 PM
ebay
Thanks man!
vanagon40
Greenwood, IN
Re: Wheel weights
Reply #9 on:
August 02, 2011, 07:53:35 PM »
Or buy a set of chrome adhesive weights and replace the ones that are coming loose.
24 weights of 1/4 oz each for $8.39 to your door off ebay.
