February 03, 2026, 02:22:30 AM *
Author Topic: What modification next?  (Read 2718 times)
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« on: August 02, 2011, 06:14:01 PM »
Trying to figure out what my next mod will be.  Here is what I have done to my 99 Standards since I have bought it:
Lots of chrome
Champion Sidecar bags
Car Tire
Rear turn signals/driving & brake lights
Desmog
Just wondering what others have done and like?
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
Pete
« Reply #1 on: August 02, 2011, 06:26:29 PM »
For cold weather riding I built some "wind wings" using lexan to keep the cold air off of my legs and decrease the buffeting at the waist level. Moved the horn to the front crash bar using an IS bracket.
Cost less than $25.00
Best thing I have done lately.
designer
Columbus, Ohio
« Reply #2 on: August 02, 2011, 06:30:54 PM »
Pictures.?
2002 Valkyrie Std
K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
fordmano
San Jose, CA.
« Reply #3 on: August 02, 2011, 09:58:57 PM »
Well stop me if you want too. Should I post the link to "ALL" of my stuff that was recently finished?
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
fordmano
San Jose, CA.
« Reply #4 on: August 02, 2011, 10:01:52 PM »
Too late,,, 2funny
Start here view twice and see what ya like the sound of!
http://www.valkyrieforum.com/bbs/index.php/topic,21439.0.html
This should keep you busy for a weekend or two. crazy2
83GS550
93XR650L TARD!
97WR250
01YZ125(x2)
05DRZ-125
9Ball
« Reply #5 on: August 02, 2011, 10:55:22 PM »
suspension upgrade and risers....improves handling performance.  Should be higher on the list than chrome, but to each their own...
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
PhredValk
Edmonton, Alberta, Canada
« Reply #6 on: August 02, 2011, 11:05:50 PM »
Horns! Air horns, Stebel horns, BigBF horns.
Cruise control (if you're on the hi way a lot).
Performance exhaust, or glass pack muffler mods.
And when you run out of normal ideas...
Fred.
« Last Edit: August 02, 2011, 11:07:37 PM by PhredValk » Logged
VRCCDS0237
fordmano
San Jose, CA.
« Reply #7 on: August 02, 2011, 11:42:08 PM »
Fred.
Fred,,,, I just did that too mine also, although I managed to loose 1 friggen pipe. so I ended up making a temp fix until I get the cash for a proper matched replacement tip.
Can you guess the temporary one I made up?
83GS550
93XR650L TARD!
97WR250
01YZ125(x2)
05DRZ-125
suthrncop
mobile, AL
« Reply #8 on: August 03, 2011, 01:24:46 AM »
 cooldude cooldude cooldude
add you A$$ to the seat and ride the he77 out of it!!!! Evil
MacDragon
My first Valk VRCC# 32095
Middleton, Mass.
« Reply #9 on: August 03, 2011, 03:38:45 AM »
Fred.
Yup... first one (long) on the right near tire... cooldude  good job on it.
Patriot Guard Riders
Pete
« Reply #10 on: August 03, 2011, 08:59:24 AM »
Pictures.?
Will try to take some today and post to this thread.
The Anvil
Derry, NH
« Reply #11 on: August 03, 2011, 09:09:19 AM »
Twin turbos with NAAAAAAAAWS!!!
BradValk48237
Oak Park, MI
« Reply #12 on: August 03, 2011, 02:12:56 PM »
+1 on the horns.... best bang for the buck... and you will use them more than chrome.... Wink
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #13 on: August 03, 2011, 05:09:35 PM »
I have a Stebel horn installed underneath.
Someone said to post pictures.  Here is a link to many pictures of my Valk.
Click Here
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #14 on: August 03, 2011, 06:37:03 PM »
Ultimate Big Boy and I would recommend it.  The only thing I do not like about it is that it is not waterproof because of the stitching.
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« Reply #15 on: August 04, 2011, 04:54:44 PM »
Zeuss' bike:
Hmmmm...I'd get some red paint, and paint over that silver primer!
Mine, when I got it (notice the red??):
Kidding aside, you might think about the darkside...
And, is that an "Iron Horse" tank bib? If not, what kind? I like the great big pocket on it!
R
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #16 on: August 04, 2011, 05:55:31 PM »
Yes it is an Iron Horse bib.  Can't remember where I got it but it is great.
As for DS I went there about 5 years ago.  Won't go back.
Pete
« Reply #17 on: August 04, 2011, 07:17:02 PM »
Pictures.?
Here are the pictures.
and the details.
Parts - everything came from Ace or Home Depot
1 - sheet 1' by 2' Lexan
2 - pipe clamps with electrical ground connection 1/4x20
2 - 6" 1/4x20 carriage screws
2 - 1/4x20 nuts
8" - of 1" bicycle inner tube
4 - electrical lugs that will slide over the 6" carriage screw
4 - acorn nuts for the screws on the electrical lugs
4 - 1/2" long counter sink screws
4 - nuts to match 1/2" long counter sink screws
4 - washers for counter sink screws
4 - acorn nuts for counter sink screws
Cut the lexan into 2 6.5" x 10.25" rectangles.
On one corner of each rectangle remove 2.5" wide(from 6.5") by 3.25" long(from 10.25") section,
curve the section with a nice gradual inside curve.
Round the other corners for a pleasing outline.
Sand and polish the edges to remove any cut marks.
Drill 2 holes in each to clear the counter sink screws, these holes are centered 3.25"
from the inside and 1.5" and 5" from the bottom edge, centered on these holes
at the bottom cut a 1" by 1.5" clearance for the ground connection towers.
Counter sink the electrical lug holes to match the counter sink screws.
Remove the heads and round the ends on the 2 6" carriage screws.
Cut the inner tube into 2 4" lengths.
Polish and clean up the sides and edges of the pipe clamps.
Grind the teeth from the inside of the pipe clamp and profile the
inside of the pipe clamp to fit the upper crash bar closely.
It will be necessary to remove and re-profile some of the outside shoulders of the
pipe clamps to clear the cam belt covers.
Assemble the parts per the picture, and add acorn nuts to cover exposed threads.
Mount and check for clearances - on the windshield and turn signals.
The horn mounted in the first picture uses an Interstate horn mounting bracket and extended wiring from the original wires.
Have fun and good luck
