March 25, 2026, 11:37:39 AM *
Author Topic: Mounting LED's under your tank  (Read 3648 times)
Nico
El Diablo !!!
Chi-town Burbs
« on: August 04, 2011, 07:36:53 AM »
Question for those who have mounted LED strip lights under your tank:
Did you mount the strips to the underside of the tank or did you mount them to the frame rails that pass under the tank?
And if you did mount them to the tank, where on the tank did you mount them?
I have a set and want to install this weekend, so your input is appreciated
Nico
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #1 on: August 04, 2011, 08:19:31 AM »
My bike has the '3 LED Pods' mounted to the frame, under the tank, one on each side shining down on the Kury Tranny Covers.  I have another pair (chrome) mounted to the choke slide covers, pointing down the intake runners to the valve cover, and another pair facing forward and down, on the front frame area, to hi-lite the front forks & wheel area.
Black Dog
Don't you know...
VALKIFIED
Sugar Grove Il.
« Reply #2 on: August 04, 2011, 08:33:19 AM »
Anyone care to post pics with them lit? TIA
Some like it fast, some like it long. Valk drivers can give you both
« Reply #3 on: August 04, 2011, 09:01:03 AM »
I would think mounting to the tank would be one more thing to disconnect when taking the tank off.  I'd rather use the rails, making sure they wouldn't interfere with getting the airbox in or out.
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #4 on: August 04, 2011, 10:05:43 AM »
I mounted mine to the frame under the tank. An 18-light strip on both sides, and a 15-light strip under each carb slide cover:
bscrive
Ottawa, Ontario
« Reply #5 on: August 04, 2011, 12:33:17 PM »
I also mounted mine on the frame, they light up similar to doubletree's but mine is a 10 light strip.  Although, I always forget that they are there and have only turned them on 5 times in the last 5 years.
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #6 on: August 04, 2011, 01:51:43 PM »
For the love of god, there's no 'r' in my handle. Even my name tags at the last two InZanes were incorrect. It's 'doubletee' - as in 2 Ts.   tickedoff
(Just poking fun. I'm not really upset about any of it.  Cheesy   )
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« Reply #7 on: August 04, 2011, 06:31:28 PM »
For the love of god, there's no 'r' in my handle.  It's 'doubletee' - as in 2 Ts.   tickedoff
Double-TEE??
There's not a SINGLE-tee, between the two of them!!
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
Traveler-MI
Cleverly disguised as a responsible adult
Nowhere In Particular
« Reply #8 on: August 04, 2011, 06:41:58 PM »
Did you have to remove the tank to do it?
Traveler
Why?  I explain it all here:
http://travelerswords.com
Traveler's Random Mental Wanderings & Contemplations
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #9 on: August 04, 2011, 06:49:44 PM »
Yes. I had to remove the tank to replace the air filter, so I installed them while the tank was off.  No other way (that I could find) to reach that part of the frame without removing it.
Traveler-MI
« Reply #10 on: August 04, 2011, 06:57:08 PM »
Have not done that yet,  sounds like a winter projekt   coolsmiley
Traveler
alph
Eau Claire, WI.
« Reply #11 on: August 04, 2011, 07:21:19 PM »
along the lip at the bottom of the tank
some in the pods
some on the trunk
about 200 in all
Walküre
Oxford, Indiana
« Reply #12 on: August 04, 2011, 07:29:23 PM »
Traveler - it takes about 10 minutes to pull the tank off, iffen you have to look for your sockets. Two bolts (one 8mm, one 10mm socket/wrench), a vacuum line (if you have the stock petcock) and a fuel line, and badda-bing, it's off. Of course, the more gas you run out of it, the lighter it is. If you have an interstate, it has the fuel gauge sender unit, so that's a connector. Not much to it, at all.
While under there, it's a simple thing to change the air cleaner - and check all your vacuum lines, etc, that you can get to.
Alph - I believe they can see you coming....AND going!!
Roger
Roger Phillips
Oxford, IN
VRCC #31978
alph
Eau Claire, WI.
« Reply #13 on: August 04, 2011, 08:16:01 PM »
Roger
that's the idea cooldude
PAVALKER
Pittsburgh, Pa
« Reply #14 on: August 04, 2011, 08:35:04 PM »
I mounted PODS and Bars on mine in various locations pointing toward the engine etc.  Could use some more, or something under the tank (if I get the urge to do it).   I do have two individual bulbs on the edge of the shield between fairing and shield (one on each end) to light up the shield and a few inside the the headlight area to illuminate that,  a pod pointing down under the trunk, a bar point down toward the rad cover.
Here is one view.... an early evening pic
And here is another.... in a lit garage
John
Reb
Greeneville, TN
« Reply #15 on: August 04, 2011, 09:29:32 PM »
I don't have any under the tank yet. With speakers, LED's and GPS wiring, I'm running out of storage room under my seat for more wires  Undecided
2022 Honda Goldwing Tour DCT
1999 Honda Valkyrie IS
1972 Honda CB350F
1978 Honda CB550K
1968 Honda CL175 Sloper
ValkFlyer
Antioch, CA
« Reply #16 on: August 05, 2011, 02:23:19 AM »
At the risk of alienating some you....IT'S A MOTORCYCLE not Disney on Parade  2funny
Just poking fun.... cooldude
Walküre
Oxford, Indiana
« Reply #17 on: August 05, 2011, 03:00:34 AM »
Must be catching on, I've now seen two or three Harley's around here, all lit up.  Usually, just the riders are.
R
Roger Phillips
Oxford, IN
VRCC #31978
alph
Eau Claire, WI.
« Reply #18 on: August 05, 2011, 05:07:27 AM »
that is funny!!  ;Dyou have to know when to say enough!! the only LED's i plan on putting on my cycle now are for the turn signals.   i have a friend that's got a goldwing with over 300LED's onit!!  but back to the original question....  i found my LED's on ebay.  type in LED strips, or lights and you'll get a slue of "chineese" companies selling 'em!!  be carefull though, there is a lot of truth to the "you get what you paid for" statement!!  i believe that LED's is the quiet reply to "loud pipe saves lives" where "bright lights save lives!!"
tg
Germany
« Reply #19 on: August 05, 2011, 05:54:58 AM »
Here some ideas for LED's from germany.
Greetings from Germany
Thomas #5785 and Kerstin
PAVALKER
Pittsburgh, Pa
« Reply #20 on: August 05, 2011, 06:34:54 AM »
Those Germany photos are "files not found"..... no bike/led pictures.
John
tg
Germany
« Reply #21 on: August 05, 2011, 07:43:35 AM »
I don't know why, but I can see the pictures.
No problem, here is a link where you can see some pictures from our last german rally.
http://www.pixum.de/slide/5730094
