November 23, 2025, 12:31:54 PM *
Author Topic: Final Drive  (Read 1305 times)
tja22
« on: August 05, 2011, 07:54:39 AM »
Could someone number the steps on putting the final drive back on the bike.
I've had trouble with the final drive and splines.  Its sounds like the most criticial step is getting the axles tightened then tighten the nuts for the final drive near the drive shaft.  thanks
« Reply #1 on: August 05, 2011, 09:21:13 AM »
First make sure the right shock is off the 4 bolts holding the final drive on the swing arm are finger tight and the pumpkin is loose (make sure it moves easily)
Second instal the wheel (with flange), axle, spacer, brake caliper plate and axle nut.
Third, screw in the holding pin for the caliper plate, make sure it goes in its little hole
Fourth, torque the axle nut to 81ftlbs making sure nothing is blocking the final drive from free movement.
Fifth immediately after the axle nut, torque the four nuts on the final drive mount to 47ftlbs.
Now just put everything else on however you like
« Last Edit: August 05, 2011, 09:23:26 AM by Chrisj CMA » Logged
X Ring
VRCC #27389, VRCCDS #204
« Reply #2 on: August 05, 2011, 10:35:58 AM »
+1
Marty
Daniel Meyer
The State of confusion.
« Reply #3 on: August 05, 2011, 11:03:35 AM »
Really good resource here:
http://valkyrieriders.com/shoptalk/
CUAgain,
Daniel Meyer
