February 03, 2026, 02:23:51 AM *
Author Topic: synthetic castrol 15-50  (Read 2898 times)
slider
mulberry arkansas
« on: August 08, 2011, 06:36:53 AM »
anyone eve use this??Im going on trip thru oklahoma-kansas-into colorado then  back  and am changing oil today before I leave...any input welcome
a proud navy veteran
F6Dave
« Reply #1 on: August 08, 2011, 06:48:25 AM »
Haven't used it.  However, with the triple digit temps they've been seeing in that part of the country, the higher viscosity may be a good thing.
csj
Peterborough Ontario Canada
« Reply #2 on: August 08, 2011, 07:09:14 AM »
I use 15-50 semi-synthetic. My mechanic highly recommended it.
Only complaint I can say is, first thing in the morning, its cool
get on it hard, the clutch slips, but just 5 min. later, bike is warm
enough that clutch stops slipping. Just my experience with semi-syn.
Full syn could work better.
« Reply #3 on: August 08, 2011, 07:12:12 AM »
If you have been using Dino up until now, I would suggest not changing to a different oil like you suggest.
It would be better to wait until you get home to experiment with the oil.
John U.
Southern Delaware
« Reply #4 on: August 08, 2011, 01:43:38 PM »
I think the clutch slippage problem is caused by friction modifiers in the oil not whether it's synthetic or a blend of synthetic and dino oil. Most car oil has friction modifiers to some degree.
Many of us have used Mobil One synthetic 15w50 and some have had clutch slipping problems. I make my own blend by adding diesel oil (which has no friction modifiers) 1 to 1 with Mobil 15w50. I haven't had slipping since I started using my version of semi-synthetic oil. You can't go wrong with a diesel oil, pretty cheap too.
As the saying goes, your bike, your choice.
Gear Jammer
Yeah,,,,,It's a HEMI
Magnolia, Texas
« Reply #5 on: August 08, 2011, 04:57:00 PM »
Which diesel oil?
John U.
Southern Delaware
« Reply #6 on: August 08, 2011, 05:29:40 PM »
I use Mobil Delvac 15w40. Chevron Delo or Shell Rotella would work as well.
valkyriemc
NE Florida
« Reply #7 on: August 08, 2011, 05:37:21 PM »
Follow link and scroll down to read abt motorcycle use.
http://en.wikipedia.org/wiki/Shell_Rotella_T
Veteran USN '70-'76
Brad
Reno, Nevada
« Reply #8 on: August 08, 2011, 06:01:33 PM »
I have been using Mobil 1 10W40 High Mileage.  The Mobil 1 High Mileage oils have no friction modifiers.
Red Diamond
Beaumont, Texas
« Reply #9 on: August 08, 2011, 09:06:42 PM »
Which diesel oil?
Bobby, he probably doesn't know you are a diesel oil expert.
