February 03, 2026, 03:50:07 AM
vacuum lines?
Topic: vacuum lines? (Read 1721 times)
scarylarry
wis rapids, wi
vacuum lines?
August 11, 2011, 01:17:23 AM »
hi all....I have a hole in the # 3 vacuum line...what is the easiest way to replace....how to get @ the T connecter is what I'm asking I guess...thanx in advance....ps..97 standard
Shotgun
Canadian Lakes, Michigan
Re: vacuum lines?
August 11, 2011, 03:39:38 AM »
You may be able to fish for it but it isn't easy. If you haven't changed your air filter for a while, then just pull the tank and change the filter and the line at the same time. It may be time to change all your vacuum lines anyway.
X Ring
VRCC #27389, VRCCDS #204
Re: vacuum lines?
August 11, 2011, 04:50:07 AM »
Shop Talk is your friend.
http://www.valkyrieriders.com/shoptalk/AirBox%20VentHose/venthose.htm
Marty
X Ring
Re: vacuum lines?
August 11, 2011, 04:51:26 AM »
Quote from: Shotgun on August 11, 2011, 03:39:38 AM
The airbox would still be in the way.
Marty
Re: vacuum lines?
August 11, 2011, 05:10:53 AM »
The string trick!
97BLKVALK
VRCC#26021
Detroit Lakes, MN
Re: vacuum lines?
August 11, 2011, 09:10:41 AM »
scarylarry....
Give Rich a email at Red Eye custom high quality vacuum lines at fair prices. If one is bad they all need changing.
http://redeye.ecrater.com/c/1086116/vacuum-line-cap-kits
Ride on!
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
Re: vacuum lines?
Reply #6 on:
August 11, 2011, 04:44:49 PM »
Like Chris said.. Its also in shop talk or archives.. I don't think its too hard too remove a couple intakes and just squeeze yourself in there,but, its been a long time.. You're not replacing just #3 line?? I know, but, had to ask.. Good line/hose and caps[or make your own] can be found at your friendly local vacuum line store..
