February 03, 2026, 04:09:48 AM *
Author Topic: Jeff K....re. the t-stat.  (Read 1284 times)
« on: August 16, 2011, 02:25:56 PM »
I picked up a stat at Autozone using the Duralast p/n you listed for the higher flow. Also got a new gasket for it and and found the Duralast p/n is the same as the Fel-Pro p/n(#25565). When I slipped the gasket on it's a perfect fit, no slop, etc.
I didn't install it as yet, lack of ambition mostly since it's a bit of a PITA. Just passing on info....nothing more.  cooldude
