May 02, 2026, 10:50:56 AM *
Author Topic: electric fences  (Read 1602 times)
doubleminded
denton texas
« on: August 17, 2011, 05:51:45 AM »
>     If you have ever used an electric fence or know someone who has one you should read this.
>     The language used is a bit salty, but 'he tells it like it is' without cursing.
>     If you don't laugh hysterically at this,....CHECK YOUR PULSE...this is funny....and true. This was sent by a retired dentist.
>     We have the standard 6 ft. fence in the backyard, and a few months ago, I heard about burglaries increasing dramatically in the entire city. To make sure this never happened to me, I got an electric fence and ran a single wire along the top of the fence.
>     Actually, I got the biggest cattle charger Tractor Supply had, made for 26 miles of fence. I then used an 8 ft. long ground rod, and drove it 7.5 feet into the ground. The ground rod is the key, with the more you have in the ground, the better the fence works.
>     One day I'm mowing the back yard with my cheapo Wal-Mart 6 hp big wheel push mower. The hot wire is broken and laying out in the yard. I knew for a fact that I unplugged the charger. I pushed the mower around the wire and reached down to grab it, to throw it out of the way.
>     It seems as though I hadn't remembered to unplug it after all.
>     Now I'm standing there, I've got the running lawnmower in my right hand and the 1.7 giga-volt fence wire in the other hand. Keep in mind the charger is about the size of a marine battery and has a picture of an upside down cow on fire on the cover.
>     Time stood still.
>     The first thing I notice is my pecker trying to climb up the front side   of my body. My ears curled downwards and I could feel the lawnmower ignition firing in the backside of my brain. Every time that Briggs & Stratton rolled over, I could feel the spark in my head. I was literally at one with the engine.
>     It seems as though the fence charger and the piece of crap lawnmower were fighting over who would control my electrical impulses.
>     Science says you cannot crap, pee, and vomit at the same time. I beg to differ. Not only did I do all three at once, but my bowels emptied 3 different times in less than half of a second. It was a Matrix kind of bowel movement, where time is creeping along and you're all leaned back and BAM BAM BAM you just crap your pants 3 times. It seemed like there were minutes in between but in reality it was so close together
>     it was like exhaust pulses from a big block Chevy turning 8 grand.
>     At this point I'm about 30 minutes (maybe 2 seconds) into holding onto the fence wire. My hand is wrapped around the wire palm down so I can't let go. I grew up on a farm so I know all about electric fences ... but Dad always had those piece of crap chargers made by International or whoever that were like 9 volts and just kinda tickled.
>     This one I could not let go of. The 8 foot long ground rod is now accepting signals from me through the permadamp Ark-La-Tex river bottom soil. At this point I'm thinking I'm going to have to just man up and take it, until the lawnmower runs out of gas.
>     'Damn!,' I think, as I remember I just filled the tank!
>     Now the lawnmower is starting to run rough. It has settled into a loping run pattern as if it had some kind of big lawnmower race cam in it. Covered in poop, pee, and with my vomit on my chest I think 'Oh  God please die .... Pleeeeaze die'. But nooooo, it settles into the rough lumpy cam idle nicely and remains there, like a big bore roller cam EFI motor waiting for the go command from its owner's right foot.
>     So here I am in the middle of July, 104 degrees, 80% humidity, standing in my own backyard, begging God to kill me. God did not take me that day.... he left me there covered in my own fluids to writhe in the misery my own stupidity had created.
>     I honestly don't know how I got loose from the wire ....
>     I woke up laying on the ground hours later. The lawnmower was beside me, out of gas. It was later on in the day and I was sunburned.
>     There were two large dead grass spots where I had been standing, and then another long skinny dead spot where the wire had laid while I was on the ground still holding on to it. I assume I finally had a seizure and in the resulting thrashing had somehow let go of the wire.
>     Upon waking from my electrically induced sleep I realized a few things:
>     1 - Three of the fillings in my teeth have melted.
>     2 - I now have cramps in the bottoms of my feet and my right butt cheek (not the left, just the right).
>     3 - Poop, pee, and vomit when all mixed together, do not smell as bad as you might think.
>     4 - My left eye will not open.
>     5 - My right eye will not close.
>     6 - The lawnmower runs like a sumbitch now. Seriously! I think our little session cleared out some carbon fouling or something, because it was better than new after that.
>     7 - My nuts are still smaller than average yet they are almost a foot long.
>     8 - I can turn on the TV in the game room by farting while thinking of the number 4 (still don't understand this???).
>     That day changed my life. I now have a newfound respect for things. I appreciate the little things more, and now I always triple check to make sure the fence is unplugged before I mow.
>     The good news, is that if a burglar does try to come over the fence,   I can clearly visualize what my security system will do to him, and THAT gives me a warm and fuzzy feeling all over, which also reminds me to triple check before I mow.
Reply
Forward
[Available] Ron Bayless
ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ahj ahah ah aha ahhh ha...
7:40 AM (10 minutes ago)
sounds like dad doesnt it?
7:41 AM (9 minutes ago)
ReplyReply
More
   from   [Available] Ron Bayless ronbayless57@gmail.com
to   dottiegarner@yahoo.com
date   Wed, Aug 17, 2011 at 7:41 AM
subject   Fwd: Electric Fence
mailed-by   gmail.com
hide details 7:41 AM (8 minutes ago)
I think you will find this funny.
---------- Forwarded message ----------
Date: Wed, Aug 17, 2011 at 7:41 AM
Subject: Fwd: Electric Fence
- Show quoted text -
Reply
Forward
No Terminal Needed - Process Credit Card Transactions
From Any PC. Call 888.208.1593
www.ChasePaymentech.com
AD
People
Rachel
rdr00714@aol.com
dottiegarner
mouthkteer
mouthkteer@aol.com
Ads
3 Bureau Credit Report
View your latest Credit Scores from All 3 bureaus in 60 seconds for $0!
www.FreeScoreOnline.com
Ally® Bank Official Site
Open an Online Savings Account at Ally® Bank, Member FDIC. Apply Now!
www.Ally.com
Overstock iPads: $30.93
Get 32GB Apple iPads for $30.93. Limit One Per Day. Grab Yours Now.
www.DealFun.com/iPad
More about...
Credit Card Payment »
PayPal »
PayPal Home Page »
Donation Receipt »
About these links
Archive
Spam
Delete
Move to
Labels
More
1 of 13
0% full
Using 6 MB of your 7616 MB
©2011 Google - Terms & Privacy
Disable buzz
Last account activity: 7 hours ago
Details
Jesus likes vakyries.
Sergeant D
So your bike has how many cylinders?
Universal City, TX
« Reply #1 on: August 17, 2011, 10:41:48 AM »
I don't care who you are....now that's funny!
"It's a friggen motorcycle, it's not supposed to be comfortable, quiet or safe. The windnoise is supposed to hurt your ears, the seat should be hard and riding it should make you crap your pants every now and then."
bigguy
VRCC# 30728
Texarkana, TX
« Reply #2 on: August 17, 2011, 11:59:18 AM »
Well ..... If you're the guy it happened to, maybe not so much  2funny
Here there be Dragons.
Stormrider65
Ft.Worth, Texas
« Reply #3 on: August 17, 2011, 02:34:53 PM »
Thats friggin hilarious.  2funny  The reason why is that it happened to me many years ago. Minus the lawnmower.  The charge was not that strong but you DEFINETLY knew this was a bad thing. Great post.
Walt
In this wild and wolly world, there are only 3 things you can depend on, your brains, your bros, and your bike.  Ride free!!!
A good friend will bail you out of jail.  A true friend will be sitting next to saying "Damn, That Was Fun"
john
tyler texas
« Reply #4 on: August 17, 2011, 02:44:00 PM »
The lawnmower runs like a sumbitch now .....      2funny
vrcc # 19002
mario
NW Houston, TX
« Reply #5 on: August 17, 2011, 05:17:37 PM »
Hilarious!!!!!!  2funny
Mario
01 Valkyrie Standard (sold)
12 Suzuki V-Strom 1000
