November 23, 2025, 02:04:16 PM *
Author Topic: New discovery but......  (Read 3135 times)
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« on: August 17, 2011, 06:08:28 PM »
I am sure many of you already know how to do this.  I posted earlier that my starter button was failing.  WELL.... I figured out how to bypass the starter button and want to know if it will damage anything doing it this way.  If you turn the key to on, and jump the two terminals on the relay behind the right side cover, it will turn over and start.
Can this damage the bike in anyway?  This is not something I plan on doing daily but just incase the button fails while away from home.
Please advise.
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
« Reply #1 on: August 17, 2011, 06:34:43 PM »
Thats a high amp circuit right there.  I dont think if you need to leave them wires connected that its a good idea.  a momentary grounding just to start it, if thats all it needs seems a reasonable emergency measure though
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #2 on: August 17, 2011, 06:45:43 PM »
What I did was just cross them with a screwdriver until it fired.  That would be ok, right?
« Reply #3 on: August 17, 2011, 07:55:21 PM »
I think if it meant getting home or being stranded I would do it
Michvalk
Remus, Mi
« Reply #4 on: August 17, 2011, 08:01:23 PM »
That is basically what the relay (that your bypassing) is doing.(Minus the sparks!) Replacing the starter relay is the repair. I would do the jumper thng, as opposed to pushing the bike. Then I would find the nearest Honda shop and purchase the part cooldude
redflash
Southern New Hampshire
« Reply #5 on: August 17, 2011, 08:49:17 PM »
it's the easiest way to get her turned over when the starter button fails, won't hurt a thing. Push starting is not much of an option unless you're Superman Smiley
Mr.BubblesVRCCDS0008
« Reply #6 on: August 18, 2011, 09:04:40 PM »
What you doing with the screwdriver is ok. Been doing it for years on just about anything that has a solenoid from lawnmower to tractor or autos. Get a new relay as soon as you can thou.
    As far as push starting a valk it is fairly easy to do. I've push started mine several times because for an alt. that was going out and I was 250 miles from the house. I turn on the key put her in sec or third and hold the clutch in, get her rolling jump on the seat pop the clutch and she'll lite off. It really does have to be rolling very fast either.
redflash
« Reply #7 on: August 18, 2011, 09:11:12 PM »
Yeah, it will push start, and you better be in 2nd or 3rd or she'll just drag her rear wheel in 1st Smiley
RonW
Newport Beach
« Reply #8 on: August 18, 2011, 10:16:54 PM »
the important thing is that don't keep holding the screwdriver to the two post for an hour straight. I think 20 seconds is the most that's safe. That's even with a working relay where you can fire up the bike by using the start button. Then you have to let things rest in between tries. The wire from the starter relay to the starter-motor gets really hot. That's all I'm going by. I've never measured the amps with a voltmeter or anything like that.
2000 Valkyrie Tourer
RonW
Newport Beach
« Reply #9 on: August 18, 2011, 10:22:28 PM »
I .... get her rolling jump on the seat pop the clutch and she'll lite off. It really does have to be rolling very fast either.
You just have to be kidding. Actually, I believe you, it just beyond my ability to even contemplate hopping on the horse that way.
Algonquin Highlands, Ontario Canada
« Reply #10 on: August 19, 2011, 03:42:58 AM »
The part in question here, is it part# 38501-GN2-014 (RELAY, STARTER) which looks like it would be hard to jump, or part# 35850-MT4-000 (SW, STARTER MAGNETIC).
bigguy
VRCC# 30728
Texarkana, TX
« Reply #11 on: August 19, 2011, 07:51:57 AM »
Yep. That's how I started mine for a week until I got the start button fixed/rigged. It does help to aim it down hill if that's an option, but flat is doable. Just not UP hill. I'm 6'1" - 235 lbs - 40 " inseam. I push it from the saddle. I realize that this isn't an option for everybody, but if you've got my general build, it's not that difficult.
Here there be Dragons.
Farther
Quimper Peninsula, WA
« Reply #12 on: August 19, 2011, 09:19:11 AM »
6'1" with 40" inseam, you must look like a Daddy Longleg Spider.   Shocked
~Farther
CASABROKER
« Reply #13 on: August 19, 2011, 10:26:03 AM »
carry a push button stater switch napa $5 and some heavy gauge wire use the stater button as your screwdriver.  Ask me how I know this.  It works great. let it hang on the right side just below the seat.
9Ball
« Reply #14 on: August 19, 2011, 10:55:19 AM »
 Grin
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
valkyriemc
NE Florida
« Reply #15 on: August 19, 2011, 03:55:33 PM »
Used to jump cars in the '60s using that manuver, sometimes they were still in gear.  tickedoff
Veteran USN '70-'76
The Anvil
Derry, NH
« Reply #16 on: August 19, 2011, 04:16:15 PM »
Yeeehaaaaa!
bigguy
VRCC# 30728
Texarkana, TX
« Reply #17 on: August 19, 2011, 09:01:44 PM »
Good catch Farther. Not sure why I typed that. 30" Just had 40 on my brain.  uglystupid2
I'm actually a little short legged for my height.
« Last Edit: August 19, 2011, 09:03:15 PM by bigguy » Logged
« Reply #18 on: August 19, 2011, 09:42:25 PM »
Jumped started a tractor once with a pair of pliers. The bad thing was it was in gear and almost ran over me. Must be careful when bypassing safety stuff.
bogator
IN GOD WE TRUST------KK4KSN-------
Valley,Al
« Reply #19 on: August 21, 2011, 03:27:46 AM »
 Been starting my Murry lawnmower for 2 years with a screwdriver----just can not remember to get a solinoid for it  crazy2 crazy2
« Reply #20 on: August 21, 2011, 07:05:56 AM »
Thats why i have a rider, to help push start. She is also my reverse, which is embarrasing but I got use to it.  Embarrassed
X Ring
VRCC #27389, VRCCDS #204
« Reply #21 on: August 21, 2011, 07:43:33 AM »
 2funny
Marty
michaelyoung254
Huntsville, Texas
« Reply #22 on: August 21, 2011, 08:01:13 AM »
Don't feel bad, we all tend to add several inches to our measurements  2funny
1998 Standard - Pearl Sedona Red & Ivory Cream
Paxton
So Cal
« Reply #23 on: August 21, 2011, 04:54:15 PM »
Push starting always work... The wife's lighter went out so I pushed started her down the stairs...
with the cigarette. Evil It must have worked... err... have not seen her since!  2funny
« Last Edit: August 21, 2011, 04:56:17 PM by Paxton » Logged
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
« Reply #24 on: August 21, 2011, 05:11:11 PM »
I needed a laugh before bed, thx!  Grin
