February 03, 2026, 05:36:05 AM *
Author Topic: riser question  (Read 1494 times)
nugz
Sturgis SD
« on: August 20, 2011, 01:15:23 PM »
was wondering what the max riser one can put on a 98 tourier without extending the cables and break lines. any info would be great.
nugz
sturgis sd
Nugz
Warlock
Magnolia, Ms
« Reply #1 on: August 20, 2011, 01:44:55 PM »
The Lemont risers works well with the stock cables. Some has put the 6" deuce risers and rerouted the stock cables. I tried rerouting mine, but they kept on binding on me. So I ordered new cables. Only need 2" longer than stock for good operation of the deuce  risers. I think direct line parts  still sells the lemont risers.
http://www.directlineparts.com/product.asp?pid=519&str=2
David
« Last Edit: August 20, 2011, 01:47:47 PM by Warlock » Logged
Chiefy
Sarasota, Florida
« Reply #2 on: August 20, 2011, 02:04:26 PM »
I put these on only because I was curious if risers would help my carpal tunnel, and I didn't want to spend a lot if it didn't.  They work well, and I did not have to re-route anything.  Although I will say that the throttle cables can not go a millimeter farther.
http://cgi.ebay.com/ebaymotors/Honda-Valkyrie-GL1500-Gl-1500-Handlebar-Risers-/200639970963?pt=Motorcycles_Parts_Accessories&hash=item2eb712fe93#ht_1032wt_1167
Farther
Quimper Peninsula, WA
« Reply #3 on: August 20, 2011, 02:09:43 PM »
I put these on only because I was curious if risers would help my carpal tunnel, and I didn't want to spend a lot if it didn't.  They work well, and I did not have to re-route anything.  Although I will say that the throttle cables can not go a millimeter farther.http://cgi.ebay.com/ebaymotors/Honda-Valkyrie-GL1500-Gl-1500-Handlebar-Risers-/200639970963?pt=Motorcycles_Parts_Accessories&hash=item2eb712fe93#ht_1032wt_1167
+1, works well for me and keep the stock appearance with little installation effort.
~Farther
