February 03, 2026, 05:40:27 AM
final drive oil useage.
Topic: final drive oil useage. (Read 2024 times)
Crazy Miles
Harwich, Massachusetts on Cape Cod
August 21, 2011, 06:11:27 PM »
What will cause useage of 1 oz, and for it to darken to black after 23K. I can undstanstand the black color, however to use it with no leaks has me worried! Mobil 1 syn 75/w90 ??
Re: final drive oil useage.
August 22, 2011, 07:35:06 AM »
1 ounce of liquid is a small amount so I would think your method of determination for usage may be faulty.
You should see evidence of leaks if there is an actual loss of lubricant.
valkyriemc
NE Florida
August 22, 2011, 08:07:41 AM »
Most have found the original fluid, dark. Haven't ever read/heard about susequint changes being dark.
Veteran USN '70-'76
August 22, 2011, 01:22:26 PM »
Replace it with a good synthetic when you do. Let it drain out real good, then pour some fresh in and let it run out as well. It will run out partially dark, then close it off and fill. The final drive will also run cooler with full synthetic.
bentwrench
Philadelphia,Pa.
August 22, 2011, 04:36:55 PM »
The black stuff is a moly coating applied to the gears for break-in.It coupld lose an oz.or two to the pinion cup o-ring if it's not sealing.
bw
Earl in Pensacola
August 22, 2011, 04:57:10 PM »
I would suspect that it was 1 oz. short of being full to begin with. Drain and refil to the point that the 80/90wt will just begin to run out of the hole with the bike straight up level.
IMHO
Jabba
VRCCDS0197
Greenwood Indiana
Reply #6 on:
August 23, 2011, 05:54:49 AM »
Aren't you supposed to change that oil about every 10K? I do. It's CHEAP.
Jabba
Earl in Pensacola
Reply #7 on:
August 24, 2011, 06:18:44 PM »
just change it along with each new rear tire-- for me that's about every 18K and it's never been a problem-- Just use a good high quality 80/90wt and my '97 is up to 241K.
