March 25, 2026, 06:03:23 PM
Are you a "blipper" or a "basher"
Topic: Are you a "blipper" or a "basher" (Read 1099 times)
August 23, 2011, 08:28:06 AM »
Blipping makes for a happy gearbox and drivetrain
http://www.sportrider.com/ride/rss/146_0402_shift_blip_throttle/index.html
Dirk Anderson: "Blipping" the Throttle
powered by
Aeva
czuch
vail az
Re: Are you a "blipper" or a "basher"
August 23, 2011, 10:25:26 AM »
Matching the RPM when down shifting is paramount importance. I drive Semi's and matching tranny to engine RPM is just how its done. "Shocking" the rotating mass is very bad on the rod and main bearings. Any other diesel drivers are expert at this also.
That being said I dont drive on a track or have a sport bike, and brake pads are cheaper and easier to replace.
POPS 57
Motorized Bandit
Motley MN
August 23, 2011, 11:33:37 AM »
The wifes Spyder does it for her on the down shifts. She has to hit a paddle to up shift.
VALKIFIED
Sugar Grove Il.
August 23, 2011, 11:38:06 AM »
Dad taught me that when he taught me to drive stick 33 years ago.your clutch will last for ever if your doin it right.
Some like it fast, some like it long. Valk drivers can give you both
BigAl
August 23, 2011, 05:30:33 PM »
Rolling into a stop the manual says to wait till your RPM's are near idle speed and then pull in the clutch and downshift to 1st.
I try to do this when coming to a complete stop.
When entering a turn on a twisty road I match the motors rpm with thenext gear down and when in the gear of choice
I leave it there for the entire set of twisties.
Such as 3rd for the Dragon on the valk or harley.
4th is my gear of choice on the Chrerohala Skyway on both the Valk and Harley.
Did I mention this will help reduce speeding tickets.
It works great saves tires, brakes, and tranny, and clutch.
Last Edit: August 23, 2011, 05:33:06 PM by BigAl
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
August 23, 2011, 11:33:34 PM »
I have ALWAYS blipped, since my early days on dirt bikes and pedal cars. Anyone who has ridden with me, after seeing me blip down to a quick stop at a light, always asks "Wow, how did you
do
that?!?". Although easy to explain, it's VERY difficult to teach! I'll admit, the tight gearing on the Valk took some time to get used to. Had a tendency to over-rev, but got over it.
R
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
