February 03, 2026, 05:51:42 AM *
Author Topic: Hard tires  (Read 2868 times)
wiseguy
My '98 Valkyrie
French Camp, Ca.
« on: August 24, 2011, 08:16:05 AM »
Hello everyone, I am new here. I purchased my 98 a few months ago. It has Dunlop E3 radials that had only 500 miles when I got her. I have played with the tire pressure a bit, still not happy with the ride. It seems there is no give at all. Any suggestions from you experienced owners?
After being kicked in the face by my horse, Broken nose, swolen eyes, blood everywhere. My wife says and I quote; I learned something today....."It's going to take a hell of a lot more than a baseball bat"
JC
The Beast
Franklin, TN
« Reply #1 on: August 24, 2011, 08:44:22 AM »
~42-45psi front and rear for best mileage, lower pressures will eat the tire. Part of your problem may be more suspension related, so check your shock bushings.
wiseguy
My '98 Valkyrie
French Camp, Ca.
« Reply #2 on: August 24, 2011, 03:18:02 PM »
Thank you JC,
 I have checked them as you suggested, no play in the bushings. It is just such a hard ride, I wonder if I could remove some oil from the forks. What do you think?
« Reply #3 on: August 24, 2011, 03:42:53 PM »
What are the rear shock settings?
You might try lowering the # on them and see what happens.
2nd thing to  try.
Bike rolling very slow - STRAIGHT AHEAD - grab a big handful of front brake.  If there isn't much dive in the forks, I'd check to see if they are BENT.
Also call the Previous owner and ask if they had made any modifications to the front springs.   Like changing out to Progressive.....
Normally these old girls have a very nice ride.......
wiseguy
My '98 Valkyrie
French Camp, Ca.
« Reply #4 on: August 24, 2011, 05:43:11 PM »
Thanks RJ,
 I have tried all of the different settings on the rear shocks. I have them set at #1 right now. There is travel in the forks The tires just seem to hard. I will contact the old owner, he did have the fork seals replaced. Another thing is, I hear the front caliper rattle whenever I hit even the slightest bump.
I am running 36 psi. in the front and 40 psi. in the rear.
« Reply #5 on: August 24, 2011, 05:53:05 PM »
Elite's should be about 42 front and 45 rear.  Lower pressure WILL result in a very short rear tire life.
wiseguy
My '98 Valkyrie
French Camp, Ca.
« Reply #6 on: August 24, 2011, 06:01:43 PM »
Thanks BF, I will increase tire pressure as you suggest,
« Reply #7 on: August 24, 2011, 07:32:31 PM »
That said, the E3's do have very stiff sidewalls.  They won't give you a cushion soft ride.
« Reply #8 on: August 24, 2011, 07:41:25 PM »
Ditto that.  The E3s don't last longer than any other valk-specific tire for no reason.  They have the hardest compound extant.  You would probably like Avons, Metzlers, or Bridgestones better.  They will not last as long as the E3s.  I love Metz, for stick and ride, but they last the shortest.  6400 from my last front was the worst ever (42-45 constant).
PAVALKER
Pittsburgh, Pa
« Reply #9 on: August 25, 2011, 04:30:28 AM »
All good suggestions..... and especially the tire pressure ones.  For proper wear and handling keep em no lower than 40psi at minimum.  Shock bushings might not appear bad by movement, but if you pull off a shock you will see the wear marks (or worn out marks).  Stock black rubber shock bushings wear out quickly and are easily identified as worn by an "off center" looking shock eye bolt, but sometimes do not give that indication.  Best replacement bet is new Poly Shock Bushings from a VTX 1800F, part number 52489-HN0-671 (order four and replace all bushings).    Since you indicated the fork seals were replaced, it could very well be that the forks may have been overfilled to some degree, so you may want to check the fluid levels and possibly reduce it if need be.   Those E3s are a very stiff sidewall and tire overall, so that could be the problem as well.  I had a set of those that never felt right the entire time I had them on, no matter what I did.   Good luck and let us know what you finally determine to be the culprit.
John
« Reply #10 on: August 25, 2011, 06:27:48 AM »
JMHO, but I run 37 psi on my Dunlop bias tires for a softer ride and get 20K per set.  Thing is I weigh 160 lbs and ride solo, so it probly would not work for most.  Probly explains my 35 to 40 mpg.  Hoser  Wink
PAVALKER
Pittsburgh, Pa
« Reply #11 on: August 25, 2011, 06:41:40 AM »
Hmmm... so what your saying is "go on a diet" and you will ultimately get a better ride, better gas mileage and longer tire wear?  I don't think we can argue with that....    cooldude Grin
John
wiseguy
My '98 Valkyrie
French Camp, Ca.
« Reply #12 on: August 25, 2011, 07:17:37 AM »
Thanks for all the input,
 I too weigh 160 lbs. Maybe I need to eat more. I guess I will have to live with the ride for now. Again, thank you for your time and input!
Mr Steve
Feeding Hills, MA
« Reply #13 on: August 25, 2011, 10:50:19 PM »
make sure they are not real old, I had a set of dunlops start squealing in the corners because they aged before I wore them out (rare) and as a result hardened.
PhredValk
Edmonton, Alberta, Canada
« Reply #14 on: August 26, 2011, 02:26:29 AM »
If you want a softer ride, look somewhere other than tires. Tires will always be hard as hockey pucks; it's their job to provide traction, not softness.
Softer ride comes from shocks and forks. Find out what fork oil grade is in the front, try a lower shock setting for the rear, or change out fork springs and rear shocks.
Tires stick you to the road, it's not like a car where they can affect the ride, unless you want to trade a cushy ride for tire life.
Fred.
VRCCDS0237
« Reply #15 on: August 26, 2011, 04:43:56 AM »
If you are a light weight and ride solo as I do, drop the pressure five pounds, 35 psi is still safe to ride.  Can't hurt to try.  Hoser
9Ball
« Reply #16 on: August 26, 2011, 05:34:48 AM »
Thanks RJ,
the caliper noise is normal......nothing to worry about there.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
wiseguy
My '98 Valkyrie
French Camp, Ca.
« Reply #17 on: August 26, 2011, 07:07:42 AM »
okay, Thanks guys!
lucky_1_chris
Arlington, TX
« Reply #18 on: August 26, 2011, 11:03:00 PM »
Thanks RJ,
I hear ya on the caliper rattle. It's driving me insane.
1999 Valkyrie Interstate
lucky_1_chris
Arlington, TX
« Reply #19 on: August 26, 2011, 11:12:26 PM »
Thanks RJ,
Hmm.... Is it really normal?? If I run over a piece a pea gravel I get a clunk from the calipers. I've had my front wheel off 3 times, and each time the rattling goes away for about 50 miles after reinstalling... I've talked to other guys who say they have no caliper rattle. I'm not gonna be happy if I can't fix it... The slightest little bit of pressure on the front brake lever and the rattle disappears...
The Anvil
Derry, NH
« Reply #20 on: August 27, 2011, 01:54:28 PM »
I have no caliper rattle.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #21 on: August 27, 2011, 02:16:26 PM »
What do you have for rear shocks?  They could be the problem.  When I got my '97 several years ago, it seemed like the front end was the culprit of the rough ride.  I changed out the shocks...they were the originals, and everything has been fine ever since.
From re-reading the posts, I'll bet a dollar your rear shocks are Shot! coolsmiley
States I Have Ridden In
wiseguy
My '98 Valkyrie
French Camp, Ca.
« Reply #22 on: August 27, 2011, 03:13:23 PM »
The rear shocks seem fine, good travel and all. How can I find out if they are bad?
« Reply #23 on: August 28, 2011, 09:46:51 AM »
I think that there should be no caliper noise such as a rattle.  Sure the calipers are a floating system but rattles???? C'mon, that indicates something is wrong.
More that likely if you think the caliper is rattling the actual cause of the noise is one of the pads banging against the rotor when it is in the rest position.  There are stainless steel clip/pad that need replacing which are designed to prevent that particular problem.
The particular part is:    SPRING, PAD  45108-ML7-922
sugerbear
wentzville mo
« Reply #24 on: August 29, 2011, 02:20:22 PM »
i was gonna say come on ever and we'll look at it, but,, your 2 timezones away. sorry Smiley
wiseguy
My '98 Valkyrie
French Camp, Ca.
« Reply #25 on: August 29, 2011, 07:32:01 PM »
I'll get it figured out, I really think it is the tires.
