November 19, 2025, 02:37:13 AM *
Author Topic: One more time ,please  (Read 2446 times)
Spirited-6
Nicholasville, Ky.
« on: April 27, 2009, 12:10:35 PM »
some one post the right numbers for brighter headlight for a Tourer, I.E., brand, and anything to do other than plug and play. I will write it all down for furture and file where I can find it. Thanks from a SENIOR.  Embarrassed I forget, what did I ask ? OH, yea. Blub for Tourer.
Spirited-6
nortman
« Reply #1 on: April 27, 2009, 01:11:21 PM »
I have a Wagner BP1210/H4, which is a "Off Road" bulb.  It is 100 watts high beam, and 80 watts low beam.  With the headlight adjusted properly, I very seldom get flashed, and when I hit the high beam it really lights up the road.  The standard bulb is 65 high, and 45 low, I beleive.  I do run the lights off of a relay in bucket, with the switch and stock wireing just running the relay.  That's a good thing to do, even with a stock headlight.
« Reply #2 on: April 27, 2009, 01:23:42 PM »
I think you might have seen that on the BigBF.com site.  If not there, then try Rattlebars.com
