February 03, 2026, 09:09:54 AM *
Author Topic: Solution for scratched chrome  (Read 3477 times)
Hef
Opdyke, IL 62872
« on: August 25, 2011, 09:55:41 PM »
Hey guys, I have a riding buddy named Jim who has a beautiful 2010 Goldwing. Yesterday he bought a nice VTX 1800 which is in excellent mechanical condition but probably has not been washed since purchased new by first owner. He wants to give this bike to his married son who has a birthday coming up and loves to ride but can't swing the purchase of a bike right now. First he thought he would clean it up. The previous owner gave him a cleaning kit with the bike which means at some time or the other he must have thought of cleaning the bike. In this kit was a scouring type pad which was to be used with a cleaning wax also supplied in the kit. It was labeled to use on chrome only. Sadly Jim never tried the pad on a small area. He washed the bike and began to wax the chrome using the pad. He applied the wax to all the chrome, let it dry and then got sick when he started wiping it off. There are nasty scratches as a result of using the pad. He called me for any ideas on getting the scratches out. I am not sure he can. If it were mine I would try a light rubbing compound. Told him I would ask the experts. Anybody got a solution? Thanks in Advance. Hef
Mr Steve
Feeding Hills, MA
« Reply #1 on: August 25, 2011, 10:28:47 PM »
He might get lucky with a red jewelers rouge with a buffing wheel, but it depends upon how deep the scratches are.  Don't try neverdull, it will make it worse as it will fog areas you scrub with it.
9Ball
« Reply #2 on: August 26, 2011, 01:18:00 AM »
Unfortunately, once there are scratches in chrome they are permanent.  You can polish out imperfections in materials like SS and aluminum, but not chrome since it is a coating.
Some products will help camoflage the bigger scratches, but if you can catch the scratch with your fingernail, then nothing will "remove" it short of having the piece re-chromed.
Expensive lesson...one option is to have the pieces powdercoated rather than re-chromed.
Sorry for your friends luck.  No good deed ever goes unpunished.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Paxton
So Cal
« Reply #3 on: August 28, 2011, 06:11:07 PM »
Humm... I probably would feel sick too... but then, stuff happens. Cry
Not having to wake up to a flood or a fallen tree over the house caused by a storm, makes up for all the screw ups that
I made over the years...  Smiley
Now, you said that the bike looked as if it had never been washed. Are you sure that the scratches weren't there all along? ???
I would start by washing all the affected areas with dish soap and water. Sometimes the residue of some compounds
will accentuate minor imperfections. Undecided
As you suggested, whatever Jim tries next, do it say, under and / or behind the pipes. If and when he finds a potential fix,
try it in a small area of the surfaces that need fixing. Lips Sealed
Do not do this on Chromed-plastic. It'll probably peel right off. Sad
At any rate, there is a product called BLUE-JOB. It is made to remove the Blue-ish stains off the Chrome Pipes.
Would it work on scratches? I don't think so, but further research might prove me wrong.
Otherwise,  the main solution is to re-chrome.  Angry
However, if things are so bad that rubbing compound would not make it worse, I would gently try "Soft-Scrub" first,
applying it with the finest steel wool available.  Undecided
Make sure that any steel wool is thinner / smoother than the applicator given to Jim by the P.O.
If Soft Scrub doesn't work I would then apply the rubbin' compound as a last resort. Roll Eyes
Make sure that any product you use is applied in one direction, rather than using a circular motion.
Beware that some chrome pieces are not metal but plastic. If so, fixing those might be nearly impossible.
On those, the chrome might actually peel off. tickedoff
I realize that what I do is not a solution to your dilemma... and painting definitely IS NOT for everyone...
I for one prefer Black over chrome. Given my preferences, I often use rattle-can Black Primer then, Satin-Black or Semi-Gloss paint.
Many mufflers would show a straight / linear scratch that cannot be buffed out. In such cases, I mask the outer edges of the scratch
along the entire muffler...
making sure that the "design" matches on both sides. I use High heat Engine Primer and Paint and spray the exposed areas to match. Shocked
I've gotten good enough at it that some observers ask how much did it cost me to powder coat. 2funny
Finally, it is likely that most damaged pieces could be purchased used but in good condition on eBay.
I certainly hope that you folks find an acceptable solution.
Good luck. cooldude
PS: I am at the early stages of negotiating a trade; my car for a low-miles VTX 1800.
"Life is what happens to you while you're busy making other plans."
John Lennon
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
X Ring
VRCC #27389, VRCCDS #204
« Reply #4 on: August 28, 2011, 06:36:30 PM »
According to a antique motorcycle restorer, never use steel wool.  The wire has a square cross section and will scratch the surface you're using it on.  No matter how minute.  He uses SOS or Brillo pads.  The wire used in them has a round cross section and will not scratch.
Marty
Paxton
So Cal
« Reply #5 on: August 28, 2011, 07:03:46 PM »
Marty;
Good to know. Thanks!  cooldude
J. Paxton Gomez
So Cal... 91205
Grumpy
Tampa, Fl
« Reply #6 on: August 28, 2011, 07:36:34 PM »
Marty
SOS or Brillo pads will scratch, the steel wool to use is grade 0000, it will not scratch chrome, I have been using it for years, Much finer grade than brillo etc, main use is for polishing out finishes on wood, varnish, shellac etc. And to note I have been restoring motorcycles for 50 odd years, also make exhaust tips for Valks etc, use the quad 0 for polishing all the time.
Here is a link to a manufacture of steel wool, that shows uses of this grade.
http://www.jpennyltd.co.uk/shopping/pgm-more_information.php?id=98
« Last Edit: August 28, 2011, 07:56:17 PM by Grumpy » Logged
bogator
IN GOD WE TRUST------KK4KSN-------
Valley,Al
« Reply #7 on: August 29, 2011, 06:25:00 AM »
 WHITE DIAMOND POLISH------you will love it------ crazy2
Hef
Opdyke, IL 62872
« Reply #8 on: August 29, 2011, 06:45:00 AM »
Bogator, Where do you buy the White Diamond polish? Hef
X Ring
« Reply #9 on: August 29, 2011, 08:16:53 AM »
Saw it at an Advance Auto Parts for $15.
Marty
TomE
« Reply #10 on: August 29, 2011, 03:56:13 PM »
I have had some luck with #0000 steel wool. Mostly for cleaning off crud. It at least does not leave scratches.
If it's polishing compound or replacement, why not try the compound? I would start with polishing compound and if that works, fine. If not, try rubbing compound. What the heck, it might work!
If you have a power buffer, there are sticks meant for use on a polishing wheel that work well. They come in different colors and have different  grits. If you start with the finest and work down until you see some action, you won't go too far wrong.
John U.
Southern Delaware
« Reply #11 on: August 30, 2011, 06:35:32 PM »
The buffing rouge comes in grades for soft or hard metals. Chrome is very hard which is why it is hard to get scratches out of.  Of course, as already mentioned, it's also thin so too much buffing will eventually wear right through.
« Reply #12 on: August 31, 2011, 06:34:01 AM »
as has been stated chrome is too hard to polish scratches out. the best one can do is change the angle of light reflection, whereas looking at it one way no scratch., another way u will see the scratch, but usually this results in more fine scratches than were originally there.
« Reply #13 on: August 31, 2011, 09:24:20 AM »
Deep scratches can be cleaned with naval jelly and the painted with aluminum metal paint.
It's not pretty but it will stop any rusting.
After the paint has fully dried you can remove any excess paint leaving the remaining paint only in the scratches, somewhat like a filler.
Polishing chrome is not possible when compared to a new chrome piece. It just can't be done.
All the polishing for a chrome part is done before the chrome plating. Never afterwards.
bogator
Valley,Al
« Reply #14 on: September 04, 2011, 05:09:13 AM »
 Google it------sorry for the late reply ---work got in the way--
 White Diamond Polish.com
Bad On 3
RIDIN THE BEAST ! !
CHICAGO IL. 60638
« Reply #15 on: September 08, 2011, 07:13:39 AM »
Hi as stated White Polish works great --you need a small buffer --you will never get it by hand --you will need to work it slow but it will improve the look --buff --wipe --buff somemore till it shines--light pressure you dont want to go thru the chrome finish --
Ridin Down The Road Of Life With My Friends !! What a Ride !!
« Reply #16 on: September 09, 2011, 05:45:46 AM »
I got a scratch out of a tank cap base with blue majuc and a cotton cloth, but it took awhile, worked great
