February 03, 2026, 05:51:27 AM *
Author Topic: Does anyone know o-ring size for the Redeye quick disconnect fuel line?  (Read 1440 times)
Al in Arkansas
Pea Ridge, Arkansas
« on: August 26, 2011, 10:36:56 AM »
I've torn my o-ring on the disconnect from Redeye.  Pretty sure I should have a spare that came with it - but I don't.  Ordering today from Redeye - but DON'T want to be parked until it arrives.  Does anyone know the size of this o-ring?   Help Please!!!
Al
Mr.BubblesVRCCDS0008
« Reply #1 on: August 26, 2011, 11:11:44 AM »
Can you take it to a hardware store and just match it up? Our little true value hardware has a good selection of them and are very helpful. Just a thought as I too wouldn't want to wait to ride.
« Reply #2 on: August 26, 2011, 11:25:16 AM »
You could remove it and replace it with a piece of hard tubing. Temporarily that is!
Al in Arkansas
Pea Ridge, Arkansas
« Reply #3 on: August 26, 2011, 11:27:25 AM »
Went to my local Orielly's and they we're pretty much out of only the one that seemed to match.  They're bringing some in from a store in the next town and will have them here in a little over an hour.  Pretty sure it will be a match.
I'll know soon!  Thanks!  Al
Al in Arkansas
Pea Ridge, Arkansas
« Reply #4 on: August 26, 2011, 11:29:27 AM »
Ricky - if I can't track down an o-ring in a couple of hours I will do that.  Thanks!
« Reply #5 on: August 26, 2011, 02:03:05 PM »
Excuse me, not trying to start a war here, but why does everyone need this quick disconnect?
Do you remove the tank that much?    If you remove the tank every month for some reason or another, I can almost see the need for one.
I've got 242+ K on MGM, and the last time the tank was off was when we desmogged him, about 3 years ago.....       I just can't see the need for the damn thing.     Oops, pardon my French.
Back when they were 1st talked about here, I put one on MGM.   Worked good for awhile and then it started starving for gas up around 90.      About a week later I removed it, and I just came across it in the bottom of the junk box yesterday.
Oh well, I was just curious on the need.
Thanks in advance.
Al in Arkansas
Pea Ridge, Arkansas
« Reply #6 on: August 26, 2011, 04:10:36 PM »
RJ - I put it on to try and make the tank removal/re-install a bit easier.  Saw folks on this board talking about it, so I figured I would give it a try.  I don't remove it all that often, so frankly I'm not sure it's worth it.  I don't really find the quick disconnect all that easy to use.  It certainly is a step up from removing the fuel line from the petcock, but not that much.
Had the tank off for carb rebuild, desmog & new petcock and just got her back together a few days ago.  Took it off today out of ignorance.  Needed to adjust my throttle cable a bit after having it apart, but it turns out I could have gotten enough adjustment at the handlebar end...
Prior to that it had been a couple years.
I suspect if I had it to do over, I would skip it.
Al
