February 03, 2026, 05:51:38 AM *
Author Topic: Clear tube under tank  (Read 1395 times)
Crazy Miles
Harwich, Massachusetts on Cape Cod
« on: August 26, 2011, 05:53:20 PM »
 Wink ok, where does  the  clear tube go under the air box?  It came undone. Goes down below???   Thanks Steve
John U.
Southern Delaware
« Reply #1 on: August 27, 2011, 10:03:55 AM »
If you mean the 5/8 to 3/4 (approx) tube, that's the "dragon drool" tube. There should be a plug in the bottom of the tube.
It needs to be connected or the engine will draw unfiltered air through the nipple, that's the reason the tube is plugged. The nipple to attach it to is near the rear of the airbox, kind of hard to get to. There should be a spring clip to hold it on IIRC.
Crazy Miles
« Reply #2 on: August 27, 2011, 01:54:35 PM »
Thanks John.  I found out were it went. cooldude The bottom went down to a T behind the alt.   Then straight down to the drool plug.  Wondering, were it T off, were does the other tube go??  Roll Eyes
