November 23, 2025, 02:00:52 PM *
Author Topic: Ride On (or other slime) + Nitrogen = Bad FYI  (Read 2173 times)
BuzzKill
Lake Dallas, Tx
« on: August 27, 2011, 08:13:18 AM »
I'm not intending on stiring up any old topics, but just want to put this out there so someone doesn't do it.
I put Ride On in my tires and took it to a local tire place to have them put it on the Nitrogen machine.  I asked them about the vacuum process and any issues with a slime based product in the tire.  They said it would suck some of it out, loosing your product and foul up their machine.  I asked about manually emptying the air and then just fill with nitrogen but they said moisture in the product would nullify any benifits from the nitrogen anyway.
I'm not sure of the science behind it, but doesn't sound worth it to me to even attempt it.
Again, just an FYI.
« Reply #1 on: August 27, 2011, 09:37:14 AM »
If you're talking about the nitrogen process for your tires (with or without Ride-On) we're in total agreement.
Ferris Leets
Catskill Mountains, N.Y.
« Reply #2 on: August 27, 2011, 10:24:16 AM »
Nitrogen sounds like a good idea but I would go with Helium.  Would make the bike lighter and give you better gas mileage.  Also you could do Donald Duck voices at parties.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #3 on: August 27, 2011, 01:00:36 PM »
I've had excellent results with a 78% nitrogen mix in my tires. cooldude
Buda
Buda IL
« Reply #4 on: August 27, 2011, 01:03:10 PM »
Could be a dumb question but why use nitrogen in your tires?
97 Valkyrie
33344
Farther
Quimper Peninsula, WA
« Reply #5 on: August 27, 2011, 01:22:42 PM »
Nitrogen in tires is a very good idea if it is free.  Otherwise stick with the free 78.09% nitrogen version available at any air compressor.
~Farther
Farther
« Reply #6 on: August 27, 2011, 02:52:02 PM »
Less pressure loss over time because the nitrogen is less likely to move through the tire material and escape.
~Farther
wiseguy
My '98 Valkyrie
French Camp, Ca.
« Reply #7 on: August 27, 2011, 03:23:36 PM »
The reason for using Nytrogen is constant pressure. It does not increase or decrease with temperature.
After being kicked in the face by my horse, Broken nose, swolen eyes, blood everywhere. My wife says and I quote; I learned something today....."It's going to take a hell of a lot more than a baseball bat"
« Reply #8 on: August 27, 2011, 04:00:01 PM »
The argument to use nitrogen is, larger molecules size resulting in less leakage.
I'll bet you a beer, every gas has the same pressure to temperature, directly proportionate, relationship.  That's the Combined Gas Law:
“ The ratio between the pressure-volume product and the temperature of a system remains constant.    ”
This can be stated mathematically as
    {pV}/{T}= k
where:
    p is the pressure
    V is the volume
    T is the temperature measured in kelvins
    k is a constant (with units of energy divided by temperature).
No, I don't use nitrogen.  I don't think it's worth the bother.  I don't personally know of any reason NOT to use it, but I have a shop compressor, and keep a tank of air in the bike barn, and don't see that using nitrogen would save me any money or effort.
« Last Edit: August 27, 2011, 04:03:49 PM by MarkT » Logged
Valkpilot
What does the data say?
Corinth, Texas
« Reply #9 on: August 27, 2011, 04:06:49 PM »
Not exactly true:
http://www.getnitrogen.org/sub.php?view=getTheFacts&subpage=temperatureeffects
http://www.getnitrogen.org/sub.php?view=nascar
As stated in the post above, putting dry nitrogen in a tire eliminates moisture and other contaminants which influence pressure changes.
As a rule of thumb, the tire pressure will change roughly 1 PSI for every 10 degrees of temperature change, regardless of the gas inside.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #10 on: August 28, 2011, 09:32:15 AM »
"The argument to use nitrogen is, larger molecules size resulting in less leakage."
That's what I've always heard and thought it (the practice) was a bunch of junk.
Of course I always find my tires seem to lose a bit of pressure constantly, not much but enough to make me get the gauge out some times and check them.
If it is a severe enough loss, then the hunt starts to find the cause of the leak, otherwise I just get out the hand pump and give it a couple of strokes.
wiseguy
My '98 Valkyrie
French Camp, Ca.
« Reply #11 on: August 29, 2011, 07:21:51 PM »
My appology, I guess I was misinformed, I had always thought constant pressure was the reason. Learn something new everyday
« Reply #12 on: August 30, 2011, 09:33:58 AM »
No, you were not misinformed.  Read the article linked to by Valkpilot:  http://www.getnitrogen.org/sub.php?view=nascar
As others have said, the reason why a nitrogen fill causes less pressure fluctuation due to temperature fluctuation is the lack of other molecules that condense and vaporize within the temperature range that tires operate at, the most obvious and common example being water.  As the tire heats, water molecules vaporize and add to the tire pressure, more so than the pressure increase due to temperature change affecting molecules that were already in a gaseous state.  If you were to fill your tires with low relative humidity air in the middle of a -40° winter cold snap, you would see similar pressure fluctuations to pure nitrogen's.
wiseguy
My '98 Valkyrie
French Camp, Ca.
« Reply #13 on: August 30, 2011, 10:27:38 AM »
Thanks for the article, very informative.
