March 25, 2026, 07:45:14 PM
beat the hurricane ride
Topic: beat the hurricane ride (Read 711 times)
August 27, 2011, 10:41:02 AM »
Found a window of grey fog to ride my Valkyrie in this morning.
Last weekend I went to ride and found my rear tire flat as I pulled up to the street in front of my house
WTF ?
Well I noticed that the valve stem cover was not on I have the fancy stem with the nuts inside and outside that is supposed to be the primo one on that back tire Bridgestone Battleaxe 200 and ride on is in the tire.
Found it at the bottom of my driveway and after using my handy plug in air compressor and pumping in 42 lbs of air I put that sucker back on
Could a not completely tightened schrader valve let that much air out? I rode over to G=Man's house to see if he had the little gizmo that comes in the rideon pack to tighten that valve I musta lost the old one as I had to have it to put the ride on in the tire in june
He found it (a miracle indeed) and it WAS not all the way tightened so I tightened it and put the cap back on
Hope that does the trick
Rode north then east then a road that goes about everywhichway and past the Dam and then decided to ride home. As I backed into the garage the skies started to open up
Timing is everything isnt it?
not even 60 miles but I will take it
Last Edit: August 27, 2011, 10:45:24 AM by Oss
Yogi Berra (Don't send it to me C.O.D.)
