February 03, 2026, 09:10:03 AM *
Author Topic: Seafoam seems to have cured my idling problem  (Read 4516 times)
Fritz The Cat
« on: August 31, 2011, 09:42:25 AM »
When I bought my Valk about 2 months ago, it would not idle at all. I had to hold a little throttle to keep it running when i stopped. Well, after about 4 cans of Seafoam and 1500 miles or so, something broke free this morning and she started idling at about 2k rpm. Backed down the idle screw to about 900 rpm and all seems well. Glad i didn't tear down the carbs like I started to,  cooldude
  Coming back from the North Georgia mountains about 2 weeks ago I accidentally put 2 cans into one tank full of gas. She ran like crap until the next fillup but maybe that helped the process along a little faster. Anyway, Seafoam and a little patience can work miracles.
« Reply #1 on: August 31, 2011, 09:54:03 AM »
You are right in how you approached the problem.
Too many riders want to tear into the carburetors and even remover the carburetor bank prematurely.
I can think of a Pandora's Box when I read that kind of suggestion.
Simple measures are best and the complex left for the last resort.  I guess when some start to have a little idling problem they are already willing to jump to the worst possible response.
« Reply #2 on: August 31, 2011, 12:19:36 PM »
Glad to hear it worked.. Sea-Foam + patience = a good thing.. I like the stuff..
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #3 on: August 31, 2011, 12:55:24 PM »
The price sure has gone up on Seafoam.  I was in a Dollar General store today and saw it for $9.  That is a company to buy stock in.
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
Dougs2000IS
Wisconsin
« Reply #4 on: August 31, 2011, 05:14:41 PM »
Check out B12 Chemtool at wallyword. If you read the ingredients its got stronger stuff in it than Seafoam. And it seams to do a better job. And CHEAPER.
2013 Victory Vision Arlen Ness
2000 Valk Interstate (sold)
1997 Ford F150
2006 Honda Civic Hybrid
Go Packers
The Anvil
Derry, NH
« Reply #5 on: August 31, 2011, 05:52:42 PM »
That's not necessarily a good thing though.
Farther
Quimper Peninsula, WA
« Reply #6 on: August 31, 2011, 08:43:41 PM »
My intake O rings started to weep after using a good dose of B12 Chemtool.
~Farther
« Reply #7 on: September 01, 2011, 09:55:46 AM »
Maybe the Chemtool dissolved all the buildup that was keeping them from weeping!
Jus sayin
thunderbass53
Colorado Springs, CO
« Reply #8 on: September 01, 2011, 10:49:06 AM »
SALE on Seafoam at Advance Auto Parts!
16 oz. can for $6.99....
Michael
1997 Valkyrie Standard
« Reply #9 on: September 01, 2011, 11:39:25 AM »
there are much better products out there at a lower cost then the religion of seafoam. Such as modern formulations by regain, redline, amsoil, chevon and the new lucas. R, C, and L avail at walmart.
SF is an old formulation and not recommended by car manufactures as a few of the new ones are. The intenet faithful have caused the rise in price.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=269397
seafoam
1. Pale oil 40-60%  just a lubricate, doesn't burn, some internet postings possible cause of hydro-lock
2. Naptha 25-35%   cleaning fluid
3. IPA 10-20%        alcohol,  doesn't your gasoline have 10% alcohol in it already?
Chevron/oronite says:
PALE OIL - straight naphthenic mineral oil, MVI to HVI, straw or pale yellow in color, used as a once-through lubricant and in the formulation of process oils
Naphtha is a cleaning fluid, lighter fluid, etc.
IPA  Isopropyl Alcohol
« Last Edit: September 02, 2011, 04:24:28 AM by CA ExhaustCoatings » Logged
The Anvil
Derry, NH
« Reply #10 on: September 01, 2011, 11:49:08 AM »
I don't give a s**t. We know Seafoam works without harsher solvents than necessary so one can a year at 8.50 or so is not a big deal. By all means try others if you want but I'm of the opinion that if it ain't broke, don't try to fix it.
FryeVRCCDS0067
Brazil, IN
« Reply #11 on: September 01, 2011, 04:06:24 PM »
Yep. It's gotten me out of carb trouble more than once without the need for carb disassembly. Once when I was a long way from home. I won't mess with success.
highcountry
Parker, CO
« Reply #12 on: September 01, 2011, 07:37:32 PM »
I have been using Techron and B-12 in the bikes and cages and both have worked well.
thunderbass53
« Reply #13 on: September 02, 2011, 11:49:02 AM »
Ditto. The Techron has been great for me too, I use it in Ruby (Valk), our Nissan Maxima, our son's F150 and his DR 350 dirt bike. It's worked VERY well on all...
Watch Advance Auto Parts...it's BOGO quite often.
Michael
« Reply #14 on: September 02, 2011, 02:49:36 PM »
I read the newer cans of seafoam and it says it is good for off season storage.  Although I don't store mine, that is a plus.  I must agree with Anvil,  Shocked It works well for me.  Hoser  Cheesy
The Anvil
Derry, NH
« Reply #15 on: September 02, 2011, 04:41:07 PM »
I don't doubt that it's popularity and brand recognition has increased the asking price though.
« Reply #16 on: September 02, 2011, 07:55:42 PM »
http://www.fuel-testers.com/is_gas_additive_safe_with_e10_list.html
http://www.automotiveforums.com/t940930-the_truth_about_seafoam.html
http://www.mediaite.com/tv/fox-news-doctor-explains-toxic-dangers-of-same-sea-foam-that-reporter-was-slathered-in/attachment/seafoam/
vicrider
Cheyenne, OK
« Reply #17 on: September 02, 2011, 08:10:20 PM »
I've had good luck with Seafoam in a couple of applications before but been leery about using in a bike. Not because it could hurt the engine but rather the tank. I don't think the Valk tank is lined like so many newer tanks are from the factory. My Victory tank is lined and some of the people who have used products other than the Victory logo cleaner have had trouble with flaking of the tank lining. My new to me Valk has not been run enough and I need to run some cleaner thru it for sure. Is it safe to dump a FULL can in the tank with fillup versus the 1 oz. per gallon I've used in cars and outboards and other small engines?
Farther
« Reply #18 on: September 02, 2011, 08:36:37 PM »
I never use less than a full can of the stuff at a time.
~Farther
YoungPUP
Valparaiso, In
« Reply #19 on: September 03, 2011, 07:52:12 AM »
I've never trusted all the vooodo oils etc, but after using seafoam to clean a spark arrestor screen from a chainsaw that was a SOLID sheet of carbon, I will never use anything alse. You may need to soak the part if its BAD, but I run it through the fuel system of everything I own, from the weedwhacker to the cages. If you have a Menards hardware store aroung its usually there for 6.99 a can. Tractor supply has it for 60.00 a gallon, and last i checked could get a 55 gallon drum if you needed it......
99 STD (Under construction)
« Reply #20 on: September 04, 2011, 03:34:19 PM »
FYI
http://www.jhodson.net/miata99/inj-cleaners.txt
http://www.f150forum.com/f7/411-additives-63987/     reasons not to use seafoam all of the time
« Reply #21 on: September 04, 2011, 03:58:49 PM »
That's why I stick to non-ethanol blended gasoline.
No problems when you can run on the non-ethanol stuff.
Here's the map for you to locate a gas station near you.
http://pure-gas.org/index.jsp
Richythebluesman
« Reply #22 on: September 06, 2011, 08:16:49 AM »
I posted this on the  "Updated on my ideling problem" and it is just as applicable here;
My stealers parts man suggested I try Starbight's Startron.
The package says it cures "ethanol problems"  Since he never steared me wrong, I bought a bottle.
Three remarkabkle things happened to my Valk; 1st the terrible exhaust smell was eliminated;
2nd the throttle response improved;
3rd the gas milage went up by 10 to 15 %.   Smiley
Usually when I pull the trailer I was getting 33 MPG, last time (with Startron) I got 38 MPG.
I tried the product in my car, the gas milage went up also to 10 to 15 % improvement from 22 highway to 27 highway MPG.
The product will do other positive things. I checked with the parts man @ Auto Zone, he rates it the best for what it does.
If it does nothing more than increase my MPG, the product pays for itself.  cooldude
« Last Edit: September 06, 2011, 08:51:43 AM by Richythebluesman » Logged
barbarianthemadserb
« Reply #23 on: September 06, 2011, 08:28:29 AM »
Thanks for the tip on Startron. I am gonna pick up some for my bikes.
