February 03, 2026, 08:48:23 AM *
Author Topic: Engine breaking up at 3000 to 4000 RPM  (Read 2288 times)
Bad Cat
« on: August 31, 2011, 09:52:00 AM »
My husband has cutomize his 2001 standard. He put air induction on it he has all the vaucume lines hooked back up. But it is now braking up between 3000 & 4000. does any one have any Ideas? Sad
« Reply #1 on: August 31, 2011, 10:02:28 AM »
I guess an explanation of "air induction system" would be helpful.
The vacuum lines incorrectly installed can also be the cause sometimes of some problem you report.
Is the bike a California bike?
« Reply #2 on: August 31, 2011, 01:32:04 PM »
If an "air induction system" involves modifiying the air cleaner box, it is a bad Idea.  Hoser
Bad Cat
« Reply #3 on: September 01, 2011, 09:26:17 AM »
No the bike is in Northern Michigan. Yes he removed the air cleaner box. The air induction is made of two tubes with foam air cleaner in each one. He has hooked all the vac. lines back up to the induction tubes. He has changed the springs on the slides. He just took it for a test ride down our rode after changing the springs and it still is beaking up. There is black smoke coming out of the pipes Undecided
« Reply #4 on: September 01, 2011, 09:48:49 AM »
Black smoke sounds like it's running rich...very rich. One thing to keep in mind re. the airbox; after all the experiments members have done with the OEM airbox, few...if any, have been able to improve on the factory unit. It is well engineered right from the factory, something most all new ventures have discovered. Put it back on and quit messing with it.
« Reply #5 on: September 01, 2011, 10:10:57 AM »
Yes, I can't add any greater positive endorsement than that of John Schmidt.
I guess your friend didn't do any reading about that specific subject (air box modifications) before doing what he did.
At least Pinwall has a bunch of stock air boxes for sale and they are plenty cheap.
Can't short the guy for trying!
« Reply #6 on: September 01, 2011, 03:58:07 PM »
Yep to what John said.. Honda got this monster right, including the air box.. If you want some shiny chrome thingys sticking out the side, add some velocity stacks.. When you were asked about the bike being a California model, that concerned emission devices..
YoungPUP
Valparaiso, In
« Reply #7 on: September 02, 2011, 06:11:47 PM »
The black smoke doesn't add up, modifying the air intake system would lean out the bike would it not? Unless the new (design) was starving the motor for air????
99 STD (Under construction)
Jeff K
« Reply #8 on: September 02, 2011, 06:27:52 PM »
I've got to say, I thought I had heard it all. Where the heck did he come up with an "air induction" for a valk?
And if he changed the diaphragm springs it could be running rich from that, but we don't have anywhere near the information we would need.
All I can say is that it is going to take a bunch of retuning to get it back in tune. My guess would be days or weeks of jetting and needle work.
But, that is the price for looking "cool". Wink
« Last Edit: September 02, 2011, 06:31:15 PM by Jeff K » Logged
Jeff K
« Reply #9 on: September 02, 2011, 06:32:53 PM »
Come to think of it... where would you even get different springs? Ace Hardware? Undecided
X Ring
VRCC #27389, VRCCDS #204
« Reply #10 on: September 02, 2011, 06:39:16 PM »
I got mine from hdlparts.  I put I/S carb springs in my Tourer.
Marty
