February 03, 2026, 07:13:22 AM *
Author Topic: gas smell  (Read 1896 times)
wildthang1949
Henderson, Tn
« on: September 01, 2011, 03:19:17 PM »
I have a strong gas smell in my garage. I have looked the bike over good and do not se a leak anywhere. Anyone have any idea what might be the problem? Also, it seems like sometimes I can smell gas fumes while riding....
sidecarrick
VRCC 13089
windsor,ontario,canada
« Reply #1 on: September 01, 2011, 03:39:30 PM »
 Possibly the seal around the gas cap. Some have had success removing the seal in the cap and adding a thin layer of gasket material and replacing the seal. Hope this helps.
sugerbear
wentzville mo
« Reply #2 on: September 02, 2011, 12:59:35 PM »
is the vent tube on, and clear?
glassguy
« Reply #3 on: September 03, 2011, 06:39:46 PM »
I got rid of the gas leakage on my '01 by replacing the intake O rings
Ken Tarver
North Mississippi
« Reply #4 on: September 03, 2011, 09:17:11 PM »
petcock leaking out the bottom maybe
SW
« Reply #5 on: September 04, 2011, 07:37:42 PM »
I had a same problem earlier this year and found that the gas cap seal (unknown reason) was the culprit. I got a thin 2 1/8" O ring that i cut and then slid under the seal using a dentist pick. Smell is gone. Good luck.
« Reply #6 on: September 04, 2011, 10:31:30 PM »
I had the same thing happen.  Very strong fuel smell.  Gas cap seal.  Just fix it or buy a new one.   cooldude
Momz
ABATE, AMA, & MRF rep.
« Reply #7 on: September 06, 2011, 06:04:59 AM »
I've had a bad gas smell in my garage when I park both my Valkyries there.
My wife found the problem. She told me to walk out of the garage when I'm about to pass gas.
Problem solved!
ALWAYS QUESTION AUTHORITY!
