November 23, 2025, 02:00:41 PM *
Author Topic: inner faring screws stuck  (Read 1077 times)
cpec4
« on: September 01, 2011, 09:26:16 PM »
Hey everyone, I'm sure this has probably been covered before, but i need some help. My past and current valkyries have all had the same problem. Those annoying little inner faring screws get stuck and when you try to take them out, the metal  piece made into the faring breaks loose from its little casing and spins with the screw...therefore not allowing it to come out so I can get to my speakers. Anyone have any suggestions???
Thanks in advance,
Chuck
fordmano
San Jose, CA.
« Reply #1 on: September 01, 2011, 11:59:40 PM »
YEP it's been covered lots of times.
But I will start the suggestions others will follow I am sure.
I have removed them a couple ways, one way is to just pry them out but that can cause damage to the fairing shell. The other way I have used was slip a very small set of needle nose pliers between the fairing shell and the speaker panel grab the insert with the pliers and apply screw driver as normal to the screw.
You can also slip a flat blade screw driver between the fairing shell and speaker panel putting a bit of pressure on the insert may keep it from spinning enough to use a screw driver like normal.
The other way is I used a high speed drill motor an just drilled the head of the screw off and removed panel leaving a little nub of the screw to remove with pliers later, this can also spin the screw and insert enough to get the insert to spin out and then use something like J-B weld to install a new insert.
Make sure you use some sort of anti seize lubricant paste when you install the new screw into the new insert.
Here is a link to the thread I posted a while back of my Multi-point upgrade and maintenance projects. Top of page 5 is some information about this exact problem of the inserts spinning and how I repaired them.
http://www.valkyrieforum.com/bbs/index.php/topic,21439.160.html
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #2 on: September 02, 2011, 04:32:43 AM »
Yep.  Fordmano is the ... well Man-o.
 2funny
Jabba
