September 18, 2025, 09:25:02 PM *
Author Topic: Front turn signal replacements  (Read 621 times)
Full_Throttle
West Frankfort, Illinois
« on: September 07, 2011, 01:42:53 PM »
Greetings.
I currently have rivco driving lights on my Valk, and for those not familiar with them, the factory turn signals attach (I believe they are factory anyway) to the bottom of the driving lights. Here is a Pic as an example (Not my bike)
Here is a picture without any turn lamps mounted
My problem is that the P.O. had the bars mis-aligned and when turning lock to lock the signal lamps would hit the radiator and they are cracked.
I would like to replace these turn signals with something better than factory.  I just HATE the fact that these are chromed PLASTIC tickedoff They feel cheap, and they are cheap.
Does anyone make a replacement turn lamp (front) that is made of metal?  Something that is NOT chromed plastic that will bolt right up to the bottom of the Rivco Driving lights like the factory ones do?
Gear Jammer
Yeah,,,,,It's a HEMI
Magnolia, Texas
« Reply #1 on: September 09, 2011, 03:15:32 PM »
Noting the tab extending from bottom of the left light's base, I'd guess you'd have trouble finding an aftermarket light with the same size/shape base as OEM with a way to accept that tab in its base.  You might have to cut off that tab which holds the OEM light in place to make an aftermarket fit.  I wasn't too happy with the chrome plastic construction either.  Sad
