February 03, 2026, 09:09:51 AM *
Author Topic: cleaning fork parts  (Read 1762 times)
theredark
Derry, NH
« on: September 07, 2011, 03:51:34 PM »
Hi all,
Just tore down  my right fork.  Need a new bushing, on order.  While waiting I figured I'd clean all the parts prior to reassembly (and brake calipers too).   I have a cheapo plastic harbor freight parts washer and it says not to use petroleum products in it.  Someone said they've used Super Clean from Walmart but it says it may damage aluminum.  Has anyone used this?  Do you dilute it or use it full strength.
Thanks all,
Brad
2000 Black/Red Interstate
Michvalk
Remus, Mi
« Reply #1 on: September 07, 2011, 05:36:37 PM »
I use Super Clean for grease cleanup. Washed the walls in my house, wash anything hard to clean. That stuff will remove the top four layers of skin from your hands. Cant say what it would do to seals in your pump in the parts washer. Good luck cooldude
Oh by the way, rinse immediatly!!!
« Reply #2 on: September 07, 2011, 05:44:32 PM »
I use brake cleaner in the spray cans.
Grumpy
Tampa, Fl
« Reply #3 on: September 07, 2011, 09:31:57 PM »
Hi all,
Thanks all,
Brad
Do not use Super clean on aluminum, I tried it on an old aluminum valve cover off a bike I scrapped. It cleaned it, but it caused the aluminum to get a white powdery finish on it, that will not come off.
If you want to be safe, mineral spirits will clean it with out damaging it.
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #4 on: September 08, 2011, 10:05:43 AM »
+1  Me too
Save a horse, ride a Valkyrie
theredark
Derry, NH
« Reply #5 on: September 08, 2011, 05:32:38 PM »
Thanks for the advice.  I did use brake parts cleaner and it worked well.  Now I just have to find out what type of grease to use to lubricate the wheel axle and the gear in the speedometer case (I got overzealous with the brake cleaner that was left over!).
Brad
RP#62
Gilbert, AZ
« Reply #6 on: September 10, 2011, 01:13:35 PM »
Mineral spirits (paint thinner) also works fine.  The ingredient in paint thinner is mineral spirits.  I check the cans at the big box stores and sometime one is cheaper than the other (marketing), but either way, its mineral spirits.
-RP
