March 28, 2026, 12:46:49 AM *
Author Topic: speedometer tachometer combo  (Read 1554 times)
Time Worp
On the first day, man created God.
Rochester, NY
« on: September 08, 2011, 01:27:31 PM »
I want to put my hoppie fairing back on and don't like the conversion kit from f6. so I'm looking to replace my speedometer & tachometer with a digital combo. Has anyone done this? if so what product did you use? Where did you mount it.
Any advice would be appreciated.
The only people you need in your life, are the ones that prove they need you in theirs.
Religious Logic: Millions of years of evolution and natural selection Imposable. Six days and magic bearded man Possible.
wekieboom
Frisco
« Reply #1 on: December 10, 2011, 01:44:02 PM »
I want this too!  did you find anything?
< boom >
Colin
My old job
Orba, Spain
« Reply #2 on: December 10, 2011, 11:12:51 PM »
What about something like this http://www.ebay.co.uk/itm/Acewell-7659-Digital-Dashboard-Digidash-Speedo-Clocks-/320804669790?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4ab172c95e They do several different models.
Like this one for without a fairing http://www.ebay.co.uk/itm/Acewell-4000-series-digital-dash-CNC-alloy-pod-Chrome-/320804667323?pt=UK_Motorcycle_Parts&hash=item4ab172bfbb
Although this one might be best for what you want http://www.ebay.co.uk/itm/Acewell-2856-Digital-Speedo-Kitcar-Quad-Latest-Model-/320804668141?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4ab172c2ed
« Last Edit: December 10, 2011, 11:15:59 PM by Colin » Logged
Colin
VRCC Espana
My Bumble Bee re-build
Time Worp
Rochester, NY
« Reply #3 on: December 13, 2011, 07:07:09 AM »
The two best options I came up without having the ugly round gauges was
If you just want speed and tach and find alternatives for oil, temp, and stand lights
http://www.google.com/products/catalog?q=speedometer+tachometer+combo+motorcycle&hl=en&rlz=1G1GGLQ_ENUS275&prmd=imvns&biw=1664&bih=923&um=1&ie=UTF-8&tbm=shop&cid=15584888178588407316&sa=X&ei=DWjnTpicDaX50gGH_cSYCg&ved=0CG8Q8wIwAA
If you want to replace all gauges (Including headlight) and by far the best looking one I found
http://www.motorcycle-superstore.com/3/13/123/25378/ITEM/Dakota-Digital-7000-Series-Spike-Speedometer-Tachometer-System.aspx?SiteID=CSE_Gbase_25378&WT.mc_ID=80003&zmam=88421133&zmas=1&zmac=45&zmap=25378
http://www.motorcycle-superstore.com/3/13/123/25385/ITEM/Dakota-Digital-7000-Series-Classic-Speedometer-Tachometer-System.aspx
YoungPUP
Valparaiso, In
« Reply #4 on: December 13, 2011, 04:50:02 PM »
I'll  do some searching, saw a set of mirrors over the summer that had the speedo, tach and indicators in the mirrors, in the glass. I'll see what i can find....
99 STD (Under construction)
« Reply #5 on: December 13, 2011, 06:20:37 PM »
I didn't think that you could replace a mechanical speedometer and tach with digital guages.  Is this possible?
¿spoom
WI
« Reply #6 on: December 13, 2011, 07:58:20 PM »
our tachs are electronic, just the speedo is mecanical. Isn't the I.S. speedo electronic? If so maybe go with an I.S. pickup. Back when the electronic speedos first started coming out there were "add-on" sending units/pickups sold also. I'm sure they are still available. Usually all you need is a square wave or sine wave going from 0v to 13v or so and many aux speedos are programmable as to how many pulses to a mile so you can go off various wheel diameters.
PhredValk
Edmonton, Alberta, Canada
« Reply #7 on: December 13, 2011, 09:22:23 PM »
In a thread called 'Valkyrie firsts' John Schmidt found this.
'PS: A clue to the next project. Now that I know how to convert the gas tank sender to work with an automotive gauge, I'm "thinking" about installing a single all inclusive gauge. It will be like one for the old Ford Bronco, speedo at the top, smaller tach at the bottom, four smaller gauges around the perimeter. They'll give me temp, oil pressure, fuel, volts...plus the face of the gauge will give me my turn signal lights and hi/lo beam, all mounted in a nice chrome housing. Just thinking...for now!!'
http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=780/category_id=636/home_id=-1/mode=prod/prd780.htm
Fred.
VRCCDS0237
Time Worp
Rochester, NY
« Reply #8 on: December 14, 2011, 04:23:55 AM »
Most companies make a cable drive sending unit
here is an example
http://www.motorcycle-superstore.com/3/13/123/25419/ITEM/Dakota-Digital-Cable-Drive-Sending-Unit.aspx
YoungPUP
Valparaiso, In
« Reply #9 on: December 14, 2011, 04:49:59 PM »
Found it!  These mirrors are made for the hardly's  but with some home work, maybe they'd work.
http://badlandsmotorcycleproducts.com/2008/Products/Digital%20Mirrors.htm
¿spoom
WI
« Reply #10 on: December 15, 2011, 08:14:18 PM »
Yeah! That looks a lot like the early ones I remember  cooldude Inside was a gear, and a Hall-effect sensor simply detected the passing gear teeth, creating a fairly square-wave signal.
wekieboom
Frisco
« Reply #11 on: December 18, 2011, 06:11:13 PM »
Wow.  O think that's what I was looking for , refering to the mechanical to electric conversion,  and the all in one style gauges.
< boom >
