February 03, 2026, 09:09:52 AM *
Author Topic: Help on Darkside install  (Read 2353 times)
valknomad
North idaho
« on: September 08, 2011, 06:34:42 PM »
1998 Valk Tourer (with Hitchdoc trailer hitch).  I'm considering Darkside car tire.  would like to run 205/60-16, but Daniel Meyer "The Dark Side" article says only a 205/55-16 will fit with NO mods.  If installing a 205/60-16, then the "fender mount cage" needs to be removed (and replace with a nut/washer... I'm thinking only a gain of 1/4" clearance per side).   A 205/55 or 205/60 are the SAME "width" of 8.07"  so up and down travel seems like either tire would hit the cage.   Yes a 55 is a "slightly" small overall dia. than a 60,  so by pure nature of the swingarm/shocks moving up and down, dia. becomes a non-issue....it's that the damm car tires a 1" wider than stock MC tire.    I'm supposing the idea is to remove the fender bolt (which is also used as the hitch bolt) which  feeds from the outside of the fender..in,  and remove the cage (from inner fender) and put the bolt from inside the fender towards the outside.. with a nut on it?     I've already screwed with the chrome saddlebag rails/hitch/bag supports enough... that I'n not excited to modify this anymore.    Thanks Vinnie.
tank_post142
south florida
« Reply #1 on: September 08, 2011, 06:42:17 PM »
just go ahead and use carriage bolts from the inside out, reducing the chance of damaging the tire if it hits on a serious bump.
I got a rock Sad
VRCCDS0246
X Ring
VRCC #27389, VRCCDS #204
« Reply #2 on: September 08, 2011, 08:42:37 PM »
Dude, it's not that difficult.  Once you pull the wheel get under the fender with a dremel tool and remove the nut cages.  Remove the welds slowly so you don't burn the paint on the exterior of the fender.  Take some primer and cover the bare metal.  Run the stock bolts back in and screw the stock nuts back on.  Then take the dremel tool and cut the bolt off where it exits the nut.  Put a little clear nail polish on the end of the bolt to keep it from rusting.  The put your darkside wheel back on.
It's not the way I'd do it but the nut will be tucked behind the fender's lip and it will keep the stock experience.  Just do one side at a time.
Marty
John U.
Southern Delaware
« Reply #3 on: September 08, 2011, 09:19:23 PM »
I just did mine with a Dremel. You only have to cut one side of each nut cage, then grab it with a pair of pliers, work it back and forth a bit. The other side tack weld will break off.
You are right, it doesn't gain much more room, but you don't need much. I mounted a 205/60 and no rubbing.
« Reply #4 on: September 08, 2011, 10:13:37 PM »
Grasshopper, you is a makin a MOUNTAIN, out of a mole hill.
Did the nut cage on mine, run a carriage bolt from the inside out, run a nut up on the outside and added an acorn nut to it, was all done.
PS:   I also have a Hitchdoc and it does not cause anymore work as it is on the outside of the fender, where ya have plenty of room to manuver.
Just remember to only do one side at a time, or you will be cussing up a storm trying to get things to line up right.
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #5 on: September 09, 2011, 05:03:10 AM »
Yep.  What everyone else says...  The nutcage mod is an EASY one.
Jabba
Cliff
Manchester, NH
« Reply #6 on: September 09, 2011, 05:47:35 AM »
You might want to try the wahser mod first,, mine was rubbing on the right side and after doing the wahser mod no more rubbing.  Did not do the nut cage mod.
VRCC # 29680
« Reply #7 on: September 09, 2011, 06:16:38 AM »
Just what every body else says. coolsmiley It ain't rocket science. 2funny My I/S has a 205-60-16 with the nut cage mod. Some folks here are running a 205-65-16 and the nut cage mod. A simple procedure when done correctly. cooldude RIDE SAFE.
Farther
Quimper Peninsula, WA
« Reply #8 on: September 09, 2011, 06:28:41 AM »
Where can a person get a "wahser"?  Roll Eyes
~Farther
CISE
« Reply #9 on: September 09, 2011, 09:55:21 AM »
Insert Quote
Quote from: Cliff on Today at 05:47:35 AM
Posted on: Today at 06:16:38 AM
At the store next to the nust
art
Grants Pass,Or
Grants Pass,Or
« Reply #10 on: September 09, 2011, 02:14:06 PM »
go to Wahl mat.In the nust section
tank_post142
south florida
« Reply #11 on: September 09, 2011, 10:30:11 PM »
asile 11d5 hadware  Wink
I got a rock Sad
VRCCDS0246
valknomad
North idaho
« Reply #12 on: September 09, 2011, 11:15:19 PM »
Thanks for the tips.. I just hated to have to screw around with my fender (chrome) fender/hitch bolts and spacers. I got it just right, and 1/4" before if hits my saddlebags.   But sure I'll run  a damm stove bolt through from the inside,  out.     I spent a month last winter fuc.ing around with the hitch/saddlebag rail, 20 trips to the hardware store and a little bit of welding to get everything "racked" just right...  so yes the cage mod is NOT Monumental by any stretch of my ability.
PhredValk
Edmonton, Alberta, Canada
« Reply #13 on: September 10, 2011, 12:17:34 AM »
I had the fender off to change the tire. Five minutes with a hacksaw and vise grips and the nut cages were gone. Squirt of black paint and put it back on. Reverse the bolts and go with acorn nuts.
Fred.
VRCCDS0237
pistolchamp
San Antonio, Texas, USA
« Reply #14 on: September 10, 2011, 02:02:22 AM »
I run a Michelin Hydroedge 205/65R16 with only the nut mod and no problems in over 90,000  miles.  The tire costs about $140 and runs over 50,000 miles, not bad eh?
