February 03, 2026, 10:41:50 AM *
Author Topic: 99 tourer rear wheel on a 99 Interstate?  (Read 1296 times)
DenverDave
Out past Mars ain't no speed limit -Mojo
« on: September 13, 2011, 08:45:18 AM »
Will a rear wheel from a 99 Tourer fit on a 99 Interstate? Will any modifications be needed? I have a chance to buy a rear wheel at a very fair price from a nearby seller. Just want to make sure it will fit.  It looks like the rotor changed on the 99 I/S and is different from the 99 tourer and standard rotor. Would it work if I replaced the rotor with one from a I/S ?  Anything else I should check?
Thanks in advance,
Dave
1999 interstate green/silver
Denver, Colorado
VRCC#32819
VRCCDS#0238
« Reply #1 on: September 13, 2011, 10:26:22 AM »
It has been a long time since I changed  wheel between a Std/Tourer and an I-State.
Seems like the wheel was the same but we had to us the I-State rotor.
If I'm wrong someone will jump in here and correct me.  Trust me on that.
tank_post142
south florida
« Reply #2 on: September 13, 2011, 11:32:45 AM »
you guys are correct. the rotor is different. you can use the original rotor or swap the caliper mount from the tourer to the I/S
I got a rock Sad
VRCCDS0246
