February 03, 2026, 01:52:23 PM
Wiring Harness
Topic: Wiring Harness (Read 1402 times)
warren
Wiring Harness
September 18, 2011, 03:06:03 PM »
I hope that I have over-killed this question. I successfully put a hitch on my bike and completed the wiring to the trailer using a Hoppy harness. The mechanic that did the install, inadvertently threw away the info on the wiring harness. It was purchased from Walmart and did not require "engineering" the wiring. I cannot remember where I found the info, but I believe I found it on this site with instructions and pictures. Do you recall seeing this on this site? I would like to file this info for future reference.
The bulbs in the trailer are standard trailer lights. Concerned about the power pull from these bulbs, any thoughts on changing them out to LED?
Thanks.
PhredValk
Edmonton, Alberta, Canada
Re: Wiring Harness
September 18, 2011, 09:19:57 PM »
I don't know anything about instructions, but trailor lights shouldn't draw enough power to be worried about. Headlights draw major power, tail lights not so much.
Fred.
VRCCDS0237
Re: Wiring Harness
September 18, 2011, 09:53:52 PM »
Assuming that the Hoppy setup has the box with the electronics in it, it will use power directly from your battery and only use the bike's turn/brake/running light circuits as triggers to switch the trailer lights. Unless the trailer has more lights than a typical small trailer, you shouldn't have problems.
RonW
Newport Beach
Re: Wiring Harness
September 18, 2011, 11:30:08 PM »
Perhaps or this
write-up.
from this
thread.
Wiring diagram for Hopkins 48245 Trailor Lights
(scroll down).
2000 Valkyrie Tourer
