February 03, 2026, 10:41:47 AM *
Author Topic: Carb reassy....lubrication?  (Read 1795 times)
Danny
Tucson, Az
« on: September 20, 2011, 07:04:15 PM »
I am doing my carbs...bike sitting for three years. Following the service manual...can/nyshould I lubricate part during reassy...example the the starting enrichment valve (SE) valve or any o rings for that matter. Cleaning right now any help asap is appreciated. Thanks
Dan
Russell Rice
I think I can, I think I can, I think I can!
Owasso, Oklahoma
« Reply #1 on: September 20, 2011, 07:40:11 PM »
you can use some silicone spray lube on the enrichment valves, works great for me. The O rings I would not lube or if you do maybe some silicone greas lube.
rodeo1
« Reply #2 on: September 20, 2011, 08:50:29 PM »
can't think of much that would need lubed, anything gas touches would wash right off anyway. does the manual you are reading reccomend it ? if not - don't - no need to repair things that ain't broke.
Warlock
Magnolia, Ms
« Reply #3 on: September 21, 2011, 04:34:29 AM »
Dan
I use Parker o-ring lub. Most places that sells o-rings should carry it. We use it offshore on the ship.
David
Gondul
VRCC #408
Central Florida
« Reply #4 on: September 21, 2011, 05:21:59 AM »
Trying to break apart all six carbs was hell.  The four rods holding them all together had all kinds of crap growing on them...
A little sanding and a little grease to facilitate future removal was my solution.
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
fordmano
San Jose, CA.
« Reply #5 on: September 21, 2011, 09:14:38 PM »
Let me be your HuckleBerry!
This is what I used and I found it at Kragens auto , (now O'reilys). about $4.xx should be enough in there for 3-4 total carb rebuilds.. or more.
Worked PERFECT, everything is as smooth as can be imagined.
I have almost 1,000 pictures of all my work from my Multipoint projects list.
http://s974.photobucket.com/albums/ae222/fordmano/Valkyrieupgradeprojects2010/
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
