February 03, 2026, 10:41:45 AM
speedometer light
Topic: speedometer light (Read 1403 times)
garyheskett All 49 x 3 st.louis
St. Louis, Missouri
speedometer light
September 21, 2011, 10:50:23 AM »
I just got some LED lights for the speedo and tach. Installed the tach light, no problem. However, the speedometer cover I am having trouble getting off. I removed the speedometer, removed the cable. and removed the screw in the end. The cover will not come off due to the odometer mileage reset knob. I guess it has to be removed to get the cover off to get to the light bulb. Geez, even with my glasses on, I can't see how the odometer reset knob comes off. Am i missing something real easy here???? As always, youalls help is appreciated.
bikerboy1951
Grand Forks, ND
Re: speedometer light
September 21, 2011, 11:26:11 AM »
There is a small phillips head screw in the knob. Unscrew it, pull the knob off and the cover comes right off.
Brad
Sergeant D
So your bike has how many cylinders?
Universal City, TX
September 21, 2011, 11:52:57 AM »
+1 on the phillips screw. It is SMALL. I had to use a screwdriver I normally reserve for my glasses.
"It's a friggen motorcycle, it's not supposed to be comfortable, quiet or safe. The windnoise is supposed to hurt your ears, the seat should be hard and riding it should make you crap your pants every now and then."
St. Louis, Missouri
September 21, 2011, 04:17:30 PM »
Thanks Bikerbou and Sgt D. I put on the strongest glasses I had and still coulnd't see the screw, but I used an eyeglass screwdriver and by golly the knob came off. Put in the new bulb and put it all back together. Now, just waiting for night time to see what it looks like. THANKS.
