March 31, 2026, 03:40:10 AM *
Author Topic: Deuce risers question  (Read 3017 times)
sidecarrick
VRCC 13089
windsor,ontario,canada
« on: September 21, 2011, 06:03:17 PM »
 OK, I'm stumped. I just installed a pair of deuce risers on my Valk and really like the positioning of the handlebars. Here's my problem- I re-routed the cables as I was supposed to and nothing seems to pull or bind, but now my throttle doesn't return, like something's tight. I spent quite a while to find the problem and I can't figure it out. Any ideas??  Thanks for the read.  Embarrassed
Tropic traveler
Silver Springs, Florida
« Reply #1 on: September 21, 2011, 06:16:19 PM »
Had a similar problem while finding the right risers for the '99. After I moved the cables behind the triple tree the throttle would not return very well, not at all off center even a little. Finally settled on 1" extensions that were not so radical that they required moving the cables back. Once I put the cables back in stock position the bind went away. Seems my Valk did not like the angle of the cables behind the tree. Longer cables are most likely required for more than a 1 1/2" departure from stock risers.
'13 F6B red for Kim
Warlock
Magnolia, Ms
« Reply #2 on: September 21, 2011, 06:25:13 PM »
Had the same problem. Ordered 2" longer than stock and cured problem. Some has re-routed and no problem. New cables solved mine.
David
Russell Rice
I think I can, I think I can, I think I can!
Owasso, Oklahoma
« Reply #3 on: September 21, 2011, 06:37:27 PM »
go get an interstate throttle housing( $53 ) from Honda and it comes with a kill & starter switch. The standard routes the cables out of the top of the housing and the interstate housing will route the cables out of the bottom of the housing. That will give you about an inch more cable and should fix your problem. That is what I did when I installed the Duce risers and it worked cooldude
Colin
My old job
Orba, Spain
« Reply #4 on: September 21, 2011, 10:56:28 PM »
+1 that's what I did and didn't have to re-route anything.
Colin
VRCC Espana
My Bumble Bee re-build
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #5 on: September 22, 2011, 04:55:29 AM »
Russell is correct if you have a standard you use a Interstate throttle housing and if you have an Interstate you simily buy the Standard cables
RonW
Newport Beach
« Reply #6 on: September 22, 2011, 05:12:53 AM »
With the I/S throttle housing on a Standard, do you still have to re-route the throttle cable? (well, I don't know.)
2000 Valkyrie Tourer
Russell Rice
Owasso, Oklahoma
« Reply #7 on: September 22, 2011, 10:01:40 AM »
You do not need to re route but since the cables are coming out the bottom it will look nicer if you do. Just makes it look cleaner.
sidecarrick
VRCC 13089
« Reply #8 on: September 22, 2011, 03:04:53 PM »
 New 2 inch over stock Pro-Motion cables are ordered and paid for. Bad thing is they're 15 days behind on their orders and they're closed for inventory next week. I guess I'll just have to remember to turn the throttle back each time. Had a CB750 that never had a return spring in the 7 years I had it. Thanks for the advice, guys.  Smiley
« Reply #9 on: September 22, 2011, 05:22:10 PM »
If you put an Interstate throttle housing on a Standard, do you use the Standard's throttle cables, or do you have to put on Interstate cables too.  I'm not following how the Standard's cables would work with the I/S's throttle housing because the Standards cables are 90 degrees to mount to the Standard's throttle housing.
Pics would be really helpful.
The Anvil
Derry, NH
« Reply #10 on: September 22, 2011, 05:28:14 PM »
Actually they're closer to 45 degrees.
Hell, I just put the drag bars on and went with custom cables. I may get the Interstate throttle housing anyway because it'll look cleaner than the standard front exit ones.
« Reply #11 on: September 22, 2011, 07:10:08 PM »
So you don't have to change the cables?
RonW
Newport Beach
« Reply #12 on: September 22, 2011, 10:34:02 PM »
You do not need to re route but since the [I/S] cables are coming out the bottom it will look nicer if you do. Just makes it look cleaner.
Thanks for the reply. The problem I had after routing the stock throttle cables outside (behind) the right fork is that the back of the right fork bumps against the cable as you turn the handlebars to the right and contorts the cable into a hairpin bend at full swing right. The pic below shows the start of the bending  .... where the cable tucks into the neck cover .... not yet at full swing right. At full swing right the throttle doesn't return. In fact neither can you roll on more throttle, not that you would need more throttle with the handlebars at that angle. It's just the fact that the throttle cable being 'locked' is not a reassuring feeling. I'm still on the fence between ordering 2'' longer cables or whether to replace the throttle housing with an I/S throttle housing with ".... since the [I/S] cables are coming out the bottom it will look nicer...." probably being a deciding factor. If memory serves, all I needed was about an inch more slack to accommodate the throttle cable at full swing LEFT.
