ShiningHorse
« on: October 01, 2011, 08:00:27 PM » |
Went to start the interstate yesterday morning after running through death valley at 115 degree outside the day before and heard the dreaded hydro lock clunk. I have never been one to turn off the fuel, except for long term storage, but from now on I will. Luckly I've been informed of the symptoms of this damaging problem by our own vrcc amen, pulled the plugs rolled the bike and fuel spat from 3&4 put back plugs all good now. Back on the road now heading to key west. Hydro lock is real, protect your bike and prevent it. Aloha
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: October 02, 2011, 04:37:52 AM » |
Good deal ShiningHorse! You used your brain instead of hitting the starter button again and shearing gears.
Marty
PAVALKER
Pittsburgh, Pa
« Reply #2 on: October 02, 2011, 06:51:03 AM » |
I had hydro lock on the lawn tractor a month ago and fortunately no damage... but I did have to drain the oil and change that out... it was diluted and full of fuel. I also installed a fuel shut off just in case.
John
« Reply #3 on: October 02, 2011, 08:24:08 PM » |
Turning off the petcock is not always going to prevent hydro lock. I have had petcocks fail and in the off position still flow fuel, just a warning.
highcountry
« Reply #4 on: October 02, 2011, 08:49:54 PM » |
Amen to that. I was changing the air filter on my now sold '98 and removed the tank which had a little fuel left in it. After a few minutes, I noticed that gas was dripping from the petcock and figured that I had not completely closed it. After fooling with it a few minutes, it still dripped. Immediately ordered a Pingel manual valve. Also, replaced the valve on my '97 as well.
« Reply #5 on: October 02, 2011, 09:37:31 PM » |
Amen to that. I was changing the air filter on my now sold '98 and removed the tank which had a little fuel left in it. After a few minutes, I noticed that gas was dripping from the petcock and figured that I had not completely closed it. After fooling with it a few minutes, it still dripped. Immediately ordered a Pingel manual valve. Also, replaced the valve on my '97 as well. Good advice! Hoser
Daniel Meyer
The State of confusion.
« Reply #6 on: October 03, 2011, 03:20:29 AM » |
And you know you have a problem with the petcock AND #3 and #4 carbs, yes?
CUAgain, Daniel Meyer
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #7 on: October 03, 2011, 01:55:04 PM » |
I would bet you have trash in your tank that has gotten into at least 2 carbs, preventing the float valves from seating.
 Save a horse, ride a Valkyrie
ShiningHorse
« Reply #8 on: October 03, 2011, 08:52:20 PM » |
Thanks for all the input, all good stuff. I'm on the road right now, so signal is spotty. Yes, I've been dealing with a low speed sputtered and have been treating it with moderate doses of seafoam hoping that will cure it. Today I increased to a more aggressive amount. In the meantime I'm doing what I can to avoid another incident, by shutting down the fuel peacock and running down the carb bowls a bit to help with maybe stuck floats or gummed up low needles, till I can do a proper fix. But of more concern now is the new coolant drip that started off the waterpump housing. Other than that she's running like a valk , all heart. Aloha
larryh0841
« Reply #9 on: October 04, 2011, 05:01:50 AM » |
I had the same problem while "on the road" and each morning I pulled the three screws out of the center cover on the front cover and turned the engine over by hand to assure there was no fuel in the cylinders. This only takes a few minutes each day and gives you confidense when you hit the starter button. It will get you home where you can do proper fix. Larry
Mr.BubblesVRCCDS0008
« Reply #10 on: October 04, 2011, 08:57:14 AM » |
Easy way is to put her in 2nd or third key off and roll her a little let the clutch out if she turns over a little good to go if not check further.
Earl in Pensacola
« Reply #11 on: October 04, 2011, 04:58:18 PM » |
Shininghorse, I couldn't help but notice your "Aloha". I lived in Hawaii (Honolulu) for 30 years. If you are from there drop me a note at justmeedp@cox.net, would like to exchange a couple of questions etc.
Sigrún
« Reply #12 on: October 04, 2011, 05:37:50 PM » |
Gotta love predictive texting with mobile phones
IBA #54465
