February 03, 2026, 10:36:36 AM *
Author Topic: HD fairing on my Valkyrie?  (Read 2005 times)
Ron44094
« on: October 02, 2011, 05:03:14 PM »
I just got hold of an 05 Ultra Classic outer fairing and would like to know if anyone has any tips on mounting it to my Tourer?  Thanks!
« Reply #1 on: October 02, 2011, 05:26:36 PM »
Memphis Shade windshield mounts is what some have used but whatever way to go you will have some fab work to do.
« Reply #2 on: October 02, 2011, 05:42:45 PM »
05 may not work, if you only use the outter shell. It will leave the inner fairning mounting holes exposed.
Mondo Limbo
« Reply #3 on: October 02, 2011, 06:41:57 PM »
What you need is the old FLH fairing, I think it's 61-83 or something like that.  Outer only.   It's almost like it was made for the Valkyrie.  It's the fairing that is open under the headlight, not the one with the the band that completes the headlight circle.  All you have to do is to sand/dremel the headlight opening to enlarge it a little.  You can adapt the stock mounts to work, I have mine mounted to standard Memphis Shades fork mounts.  The windshield and mounting hardware are available from HD and are not very pricey believe it or not.
quexpress
Montreal, Québec, Canada
« Reply #4 on: October 03, 2011, 06:03:51 AM »
The earlier style batwing fairings (mid 70s to mid 80s)
-   4 mounting studs.
-   Fairing is separate from the windshield.
One vertical bracket is bolted to a clamp on each front fork. The windshield and the fairing are then both individually bolted to the brackets.
2000 Tourer With Early Style Batwing Fairing
At the beginning of that first season, my Tourer was set up with an early style batwing fairing as follows:
Two vertical brackets on the fork clamps.
Fairing and windshield individually bolted to the brackets.
Batwing Fairings Mid 80s to Mid 90s
On My Tourer
This picture was taken while adjustments were being made to the fairing.
Note that only one bracket is used on the bottom stud of the fairing, and then 1 on each side up on the handlebars. I had used brackets fastened to all 4 studs on the fairing. The set up was super clean (what I’m looking for). However the windshield vibrated at triple digit speeds. It doesn’t vibrate when fastened to the handlebars…  Smiley
Kirk's set-up:
Newer batwing fairings (from 1996 on)
-   3 holes to fasten the windshield.
-   do not have the studs (mounting points) inside of them
The inner fairing with the gauges was the structural support for these later fairings. They simply screwed on to the inner portion once it was mounted to the bike. I had to fabricate brackets from 16 gauge metal and pop-rivet them to the small ribs that are used for rigidity, and molded into the plastic during it's manufacturing process.
Note:
Considering that these late model fairings are made up of some sort of ABS plastic, they have these reinforcement ribs molded into them for added strength. Bad news is the ribs only stick up about 1/4" from the inside surface, good news is there are two of them that run from top to bottom inside the fairing about an 1-1/2" to the outside of the forks. I was able to fabricate some long mounting brackets out of 16 gauge metal and pop-rivet it to the ribs. It's not the only place it is held on by, but is part of it.
I still have a full deck.
I just shuffle slower ...
« Reply #5 on: October 03, 2011, 08:41:01 AM »
Ron.....
Here is an excellent write-up with lots of pics on a newer HD fairing install.
http://www.valkyrieforum.com/bbs/index.php/topic,26182.0.html
POPS 57
Motorized Bandit
Motley MN
« Reply #6 on: October 04, 2011, 07:03:45 AM »
Look up 39 Chev. He has one all done up. Came out looking great.
carl1up
sardinia ohio
« Reply #7 on: October 04, 2011, 06:13:30 PM »
heres my 98 siandard-i added an 01 electraglide fairing all for about 500.00  love this bike......
