January 28, 2026, 01:55:32 PM *
Author Topic: Burnt up the clutch have some questions about replacement.  (Read 2716 times)
chrise2469
Winnipeg Manitoba Canada
« on: April 30, 2009, 09:33:35 PM »
I was a dumba$$ and thought it would be a good idea to try a burnout with my old tire.  New tire is on and now the clutch slips under load  uglystupid2.
I  have gone through the archives and have a pretty good idea what is in store.  I  have a few questions for the experts
1.  Is The basket socket nut 32mm and will a shallow socket work or is a deep socket necessary.
2.  Both Jeff K and Lady draco tightened up the basket with two bolts before reinstalling the spring-whats the thread pitch on these bolts?
3.  Whats a good way to do a burnout without killing the clutch  Wink
Thanks for the help
Chris
« Last Edit: May 01, 2009, 08:59:52 PM by chrise2469 » Logged
woody
Australia
« Reply #1 on: April 30, 2009, 09:50:30 PM »
I have found the best way to do a burnout without burning out my cutch is to use someone elses bike. 2funny
Im too scared to do a burnout on the Valk because last time I lifted the front wheel and had to ride a 100 metres before I was game enough to let the front wheel come down. I was worried that it would hit too hard and break something.
Master Blaster
Deridder, Louisiana
« Reply #2 on: May 01, 2009, 06:17:44 AM »
The clutches on these things are pretty robust, its unusual for one to go south, unless you are using the wrong oil.  They do fine even on blown bikes, most common problem is the rivets on the damper plate.  have seen tons of burnouts with no clutch problems, even on very high mileage bikes.  I would suspect that you may have something else going on that caused your problem.
chrise2469
« Reply #3 on: May 01, 2009, 03:53:21 PM »
The problem was I didn't get a nice smokey burn out.  The clutch felt great before I started and after 4 or 5 attempts it was weak and travel was way longer.  Looks very casual to me.
DFragn
« Reply #4 on: May 01, 2009, 05:30:26 PM »
If your lever engagement travel has drastically increased it is probably because of failed rivets in your damper plate. Worn friction plates shouldn't affect your lever noticeably unless they're warped.
