February 03, 2026, 10:41:44 AM *
Author Topic: CB Have I been taken for a ride?  (Read 2775 times)
« on: October 09, 2011, 01:59:49 PM »
sod me
I bought swoppies cb with the antenna
It did not come with the plug and wire that goes to the antenna or the left bracket and I
picked those up from tank  Thanks tank  Swoppie never answered my email or posts so I wont waste further time asking him directly
anyway I get error message, unit shows cb active channel up down and squelch controls show action but no incoming traffic or noise  Wearing my full face with mike I dont hear anything
 tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff tickedoff
WHat did I do wrong and what should I do right
Any suggestions ?
« Reply #1 on: October 09, 2011, 02:09:03 PM »
I don't think Brian ( Swoppie ) would sell you a turd just don't seem he would do that however that CB might have been on his bike when he crashed and he did'nt know about the damage ( if any )  Undecided
« Last Edit: October 09, 2011, 02:11:02 PM by Smokinjoe-VRCCDS#0005 » Logged
Chrome
London Ontario Canada
« Reply #2 on: October 09, 2011, 02:55:20 PM »
Hey Oss Before you get your New York nickers in a knot,did you get a manual? Do you know how to work the squelch or set the CB volumn control or even use a CB? If you didn't get the book,just ask.I can send a file.
Adrian
2001 Valkyrie I/S
1999 Valkyrie I/S
1998 Ace Tourer
1984 V45 Sabre
1976 CB 750 SuperSport
1969 CB 750 Chopper
« Reply #3 on: October 09, 2011, 03:01:33 PM »
I believe the manual is where the rest are, Valkyrie Norway downloads page.
Doesn't the radio need to be set to headset, rather than speakers, before you'll hear anything, CB also, in your headset?
« Last Edit: October 09, 2011, 03:12:05 PM by gordonv » Logged
Danny
Tucson, Az
« Reply #4 on: October 09, 2011, 05:26:11 PM »
Alright my 2 cents. I once bought a cb for my 4 wheeler and had a similar problem had to buy a cord and antenna and the same thing...no workey. I was told by the guy at radio shack that you have to buy a special meter and "tune" everyhting as a unit. The meter was kinda pricey never did try to go anyfurther because I was broke. Not much has changed. Haha!
Danny
Kingbee
VRCC# 576
Northern Illinois
« Reply #5 on: October 09, 2011, 06:12:47 PM »
I had the same problem when I installed my CB.  IRC, there's a 3 conductor connector involved, 1 is for ground and 2 are for 12v positive.  One of the 12v pos conductors was dead.  It turned out that the splice block on the bike's main wiring loom was failing.  You should be able to test your connector for 2  12v circuits and 1 gound.  If you don't have both 12volt circuits, you'll get the error message and won't hear anything.  You should be able to search the archives for a fix for the splice block.
1999 Interstate
2000 Interstate
2004 Rune
Super Santa
VRCC #27029
Houston, Texas
« Reply #6 on: October 09, 2011, 07:54:46 PM »
Another possible thought.  There is a separate volume control for the CB.  You have to have it in the CB position then adjust the volume for the CB.
Novavalker
99 Interstate/2017 Goldwing
« Reply #7 on: October 10, 2011, 05:43:31 AM »
Once upon a time I too had the ER message. There is likely nothing wrong with your radio. It isn't getting the required 12 volts.
You need a voltage meter.
Now pull your right side cover.
Locate the Blue 20 pin connector. At pin #3 harness side you will find a LT Green/Black wire, probe this wire and turn on the key switch, you should have 12 volts.  If it doesn't you can splice in a jumper wire around the bad connection. This is a quick fix method.
Since doing this quick fix I have completed the splice block mod which solves this problem (and many other electrical gremlins) at the root cause.
« Last Edit: October 10, 2011, 05:54:15 AM by Novavalker » Logged
« Reply #8 on: October 10, 2011, 02:32:18 PM »
ok
I took off the right and left cover and removed the battery
3 wires come off the cb
one for antenna one for intercom one is the 2 red and 1 blue inside the black casing leading to a connector
I do not have anything to attach to that connector  NADA
WTF
Well that certainly is not swoppies fault so I would be wrong to blame him
Where in the sam hill is that connector?  checked in the boots, behind my compressor, where were yours laying when you put in your cb and attached to what loom>
dallastar
Riden out of Hell,AZ. "Running On Empty"
« Reply #9 on: October 10, 2011, 03:50:08 PM »
SWR meter       but  thats NOT his issue   and stay out of Radio Shacks   them kids havent a clue
Danny
« Last Edit: October 10, 2011, 03:52:16 PM by dallastar » Logged
"Running On Empty"
NJF6Cowboy
« Reply #10 on: October 10, 2011, 05:39:47 PM »
Oss,
I am heading to the garage right now to look at my connections! Be right back amigo!
Stan aka NJF6Cowboy
NJF6Cowboy
« Reply #11 on: October 10, 2011, 06:01:57 PM »
Oss,
Remove right side cover, inside soft black boot, maybe deep inside, mine was, you should find a white female connector with a 12-14ga green wire, a 16-18ga red with yellow stripe wire, and a 16-18ga green with black stripe. That is what my cb is wired to ( 99 red & black I/S).
Hope this helps, if not I'm awaiting knee replacement on Oct 26 and could take a ride to help you out as I'm bored out of my mind.
cya, Stan
« Reply #12 on: October 10, 2011, 06:26:38 PM »
stan may have figured it out
when I bought the bike I had the rivco air horns installed by the mechanic
Stan told me that the connector is one of the 3 in that black boot which it appears that it feeds into my air horn.  That connector feeds into two connectors that seem to be going to that horn tracing back there is a fuse feedin into the battery
So if I disconnect it I lose my air horn  which I cant do being how I drive in NYC   Shocked
Wish I had an aux fuse block on the bike then I could work around this but its pretty tight in that right cover  Maybe the aux block could go in back of the battery?
So thanks stan and good luck on the knee surgery
If anyone wants to come over and install a aux fuse block I will buy dinner and pay for the parts
I ordered the centech ap1 fuse block tonite
« Last Edit: October 10, 2011, 07:37:25 PM by Oss » Logged
NITRO
Eau Claire, WI
« Reply #13 on: October 10, 2011, 06:59:17 PM »
There was a member selling a new CenTech fuse panel a bit ago. They are about as small of a panel I've seen and are very well made. I have had one on my Valks for the last few years. If you can't fit it under the side panel, you could definitely run it up behind the battery.
When in doubt, ride.
