February 03, 2026, 10:41:33 AM *
Author Topic: Velocity Stacks install question  (Read 1586 times)
dallastar
Riden out of Hell,AZ. "Running On Empty"
« on: October 10, 2011, 04:18:31 PM »
1st dont send me BigBF link i know all about the link and i also know how to install ...my questions is why is the front of tank raised and NOT the rear of the tank ???
"Running On Empty"
« Reply #1 on: October 10, 2011, 04:23:05 PM »
If you want to maintain the lines of the bike I guess you should raise both the front and the rear, but then the seat may not fit, but then again that can be fixed too
dallastar
« Reply #2 on: October 10, 2011, 04:27:46 PM »
the reason im askin is i bought some V stacks the person is sending the spacer and he said ti raise the rear its better ...  but every install ive read say raise the front now this guy say raise the rear
Im sure ill figure it out   i was jus wondering out loud here
"Running On Empty"
scoot
Lifes too short Ride it hard
Grand Rapids Mi.
« Reply #3 on: October 10, 2011, 05:47:07 PM »
It would be my guess that it would have something to do with he figured that you would have to go to reserve sooner and by raising the rear of the tank it moves the gas to the front of the tank instead (when almost empty). I would think by raising the front of the tank you don't have to raise it as far to get the clearance needed. Just my .02 worth.
mirion
1997 Std - 2000 IS
Frankenmuth, Michigan
« Reply #4 on: October 10, 2011, 06:52:23 PM »
Not sure if you saw the Shop Talk article I put up a little while back but it has a picture of the stack clearance with the spacer in front as well a method to put the tank back in contact with the frame. Some say that raising the front allows better air flow to the intake.
http://www.valkyrieriders.com/shoptalk/vstackspacermod.pdf
dallastar
« Reply #5 on: October 10, 2011, 07:11:36 PM »
I havent seen ur link but i hav now and ill be doing that right there ..thanks
"Running On Empty"
