March 26, 2026, 03:16:59 PM *
Author Topic: Stebel's are for wussies!!!  (Read 1548 times)
« on: October 10, 2011, 06:12:41 PM »
I bought this air horn last year at a swap meet for $10.  I finally got it mounted, 99% plumbed and wired.  I bench tested it and it is loud, should be ready for the fall color ride, so don't cut me off!!!
I used an old truck AC condenser for an air tank because it has the low pressure switch that closes @ 40psi, and a Danmarc fuel solenoid wired to the horn button to dump the tank.  I run a 12v slime compressor off the 87a (normally closed) terminal on a relay wired to the low pressure switch.  When the tank pressure drops below 40psi, the compressor kicks on, when it hits 40psi the compressor kicks off.
musclehead
inverness fl
« Reply #1 on: October 10, 2011, 06:16:26 PM »
I've thought about getting these, they run about 150-175 in truck stops.  but where to mount them.  uglystupid2 uglystupid2
Moonshot_1
« Reply #2 on: October 10, 2011, 06:19:57 PM »
You mounted a Valkyrie to an Air Horn?
That's a pretty big horn.
Mike Luken
Cherokee, Ia.
« Reply #3 on: October 10, 2011, 06:27:58 PM »
I had enough trouble trying to find a place to mount this one.  Thought about on the right side, which would have looked better, but got in the way of the foot brake, didn't think that was cool...
« Reply #4 on: October 10, 2011, 06:41:20 PM »
I used to have a set taken from a boat, found them in a used marine equipment shop in Daytona a few years back. Mounted them under my saddlebags on the Wing I had at the time, one on each side. Mounted the beer can sized compressors, one in each saddle bag. Longest trumpet was 19", the other 17". Sounded like a semi truck coming at you, didn't get ignored for sure...they were some kinda loud.
Karen
Boston MA
« Reply #5 on: October 10, 2011, 06:46:42 PM »
Remind me never to pass you on the right...
¿spoom
WI
« Reply #6 on: October 10, 2011, 07:51:04 PM »
yeah, I'm thinking on top of the trunk, facing forward, might pose problems  2funny
art
Grants Pass,Or
Grants Pass,Or
« Reply #7 on: October 10, 2011, 09:03:25 PM »
mounted my steble horn between the forks under the tripple tree.Lowered the fender 3/4 in. for clearence.workes good an loud enough.Yuo could have a train horn an some idiots still would not care.I had a woman cut me off in az. I keeped on blowing the horn an she gave me a dirty look an kept on coming.thats when a 45 would come in handy for shooting out tires
ValkFlyer
Antioch, CA
« Reply #8 on: October 10, 2011, 09:09:45 PM »
You bench tested it.   ???  Don't forget to test it on the bike before hitting the road.....I'd imagine each time the horn button is pushed the a$* end of the valk will jump 3 feet left.  Grin
« Reply #9 on: October 11, 2011, 05:59:07 AM »
Skinhead......
Can you tell me where you got those chromed lights on your license tag frame that you replaced the reflectors with?
Would there be an on-line source for those?
« Reply #10 on: October 11, 2011, 06:15:39 AM »
 Grin
Rocketman
Seabrook, Texas
« Reply #11 on: October 11, 2011, 10:40:51 AM »
With a horn like that, I doubt you need a brake!
olddog1946
Moses Lake, Wa
« Reply #12 on: October 11, 2011, 10:50:55 AM »
Well you can for sure say "Mine is bigger than yours!"
Hope you use ear plugs..and carry diapers for the cagers you scare...
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
czuch
vail az
« Reply #13 on: October 11, 2011, 11:02:20 AM »
That looks about right from here. I have a friend who's a truck driver. He has the train horns mounted on his truck. Well he calls one night to tell me he's driving by my offramp and he wants to know if I can hear his new horns. 3/4 of  a mile away they were loud, clear and left no doubt he was going by
« Reply #14 on: October 11, 2011, 03:09:09 PM »
Skinhead......
I got mine @ pepboys, they are LED trailer marker lights.  Should be able to find them anywhere on line, JC Whitney, NAPA, etc.
« Reply #15 on: October 11, 2011, 03:23:18 PM »
Skinhead......
Thank you!   cooldude
