August 21, 2025, 11:20:34 PM *
Author Topic: squeek in the front end  (Read 1018 times)
« on: October 11, 2011, 03:05:54 PM »
I have a squeek in the front when i turn the front wheel. Looked all over for a grease fitting and came up with nothing. Maybe some bushings need replaced. Any ideas guys?
« Reply #1 on: October 11, 2011, 06:54:06 PM »
Is the squeak apparent with a right as well as left turn? Has the front wheel been off lately? Loosen the front axle and retighten according to the service manual procedure. You may have something "dragging". Maybe a wheel bearing. Good luck.
My rides:
« Reply #2 on: October 11, 2011, 07:05:59 PM »
Squeeks when you spin the wheel?  or when you turn the bars left or right?
« Reply #3 on: October 11, 2011, 07:27:46 PM »
Its posted on the general board. I nailed it. Tank chrome was rubbing.
« Reply #4 on: October 11, 2011, 08:37:02 PM »
 cooldude fudgie is the man. Next time ill check everything before i ask such a stupid question. His response sent me straight to the problem. Sprayed some wd40 on it and wiped the excess off and its good as new
