I've got one. They're easy to use, but I don't use it because the ShowChrome cover will not fit over it. Mine is a different brand, and did not come with the options for different finishes this link shows, so I use a chrome filter cover. I'm sure someone will jump in and tell you how it doesn't filter the oil as well, etc etc,etc,, I can't provide any evidence regarding it filtering capablity, so I won't give my opinion and call it fact like some do. And Farther is correct, it does make a bit more work out of an oil change, but you don't have to find an "acceptable" way to dispose of the used filter either
