YoungPUP
« on: October 15, 2011, 06:40:18 PM » |
Installed a cat back exhaust for a friend today. When he asked if he needed to bring anything special, I told him to bring a pack of birthday candles. When he wanted to know why, I showed him that if you heat a rusty bolt, and then melt a candle into the joint where the bolt, and nut meet, it usually allows easy French free disassembly. I also told him about the Brake cleaner burn treatment for preventing blisters when you get a burn. Now I'm wondering what other tips and tricks are out there?
99 STD (Under construction)
designer
« Reply #1 on: October 15, 2011, 06:57:17 PM » |
Brake clean burn treatment? Do tell.
2002 Valkyrie Std K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
YoungPUP
« Reply #2 on: October 15, 2011, 07:04:23 PM » |
Unfortunately got to show this to my buddy/Tool fetcher. He grabbed one of the just heated, just removed nuts. When you make a hi temperature mistake like this spray it immediately with brake clean, (the chlorinated kind that the tree huggers dislike seems to work best.) It flash dries quickly, cooling the burn, and it strips moisture, so is usually prevents blistering.
« Last Edit: October 15, 2011, 07:08:54 PM by YoungPUP »
Valkpilot
What does the data say?
Corinth, Texas
« Reply #3 on: October 15, 2011, 08:17:22 PM » |
Brake cleaners, chlorinated or not, contain nasty solvents, almost all of which are carcinogenic. Some of these can pass through healthy skin and target various organs. This is normally a concern with prolonged exposure, but in this case is being sprayed on already damaged skin. I'm sorry, but I wouldn't recommend it. Try some of that sissy Aloe stuff instead.
« Last Edit: October 15, 2011, 08:20:11 PM by Valkpilot »
MacDragon
My first Valk VRCC# 32095
Middleton, Mass.
« Reply #4 on: October 15, 2011, 08:45:55 PM » |
Try some of that sissy Aloe stuff instead.  +1 on the Aloe. Direct from the plant... Lots of reasons why it works.
 Ride fast and take chances... uh, I mean... ride safe folks. Patriot Guard Riders
Grumpy
« Reply #5 on: October 15, 2011, 08:49:25 PM » |
Try some of that sissy Aloe stuff instead.  +1 on the Aloe. Direct from the plant... Lots of reasons why it works.  thumbs up on the aloe, we have several beds around the house, sliced a finger to the bone last year, grabbed a leaf and squeezed the juice in the cut and taped it together, 4 days later could not hardly tell it was cut. the stuff works.
« Reply #6 on: October 15, 2011, 10:53:52 PM » |
I can't help about the shape I'm in I can't sing, I ain't pretty and my legs are thin But don't ask me what I think of you I might not give the answer that you want me to
« Reply #7 on: October 16, 2011, 04:14:35 AM » |
An ice cube works if you do it immediately.
« Reply #8 on: October 16, 2011, 06:10:31 AM » |
I got blood poisning and almost died a few years back from brake cleen. I was working on some equipment and was using brake cleen with an open cut on the top of my hand. The next morning i could see all the veins in my arm up tp my arm pit, the veins were bright red. I drove myself to the ER where they proceeded to shoot my butt cheeks up with multiple meds and then told me i was lucky because if i wiuld have waited just a few more hours it would have most likley been to my heart and would have killed me. So i dont ever use any chemical for any injury.
MacDragon
Middleton, Mass.
« Reply #9 on: October 16, 2011, 06:51:48 AM » |
Can't imagine any good would come from using a chemical solvent on an open wound or burn.
Fritz The Cat
« Reply #10 on: October 16, 2011, 08:01:33 AM » |
Brake cleaners, chlorinated or not, contain nasty solvents, almost all of which are carcinogenic. Some of these can pass through healthy skin and target various organs. This is normally a concern with prolonged exposure, but in this case is being sprayed on already damaged skin. I'm sorry, but I wouldn't recommend it. Try some of that sissy Aloe stuff instead.  Troof.
YoungPUP
« Reply #12 on: October 16, 2011, 08:12:31 AM » |
Obviously, the brake clean trick isn;t for severe burns, but I've used it for fingertips etc. Is the best thing , no. Does it work in a pinch yes. Ive used aloe alot, but its not handy to keep around when working under a car....
Russell Rice
I think I can, I think I can, I think I can!
Owasso, Oklahoma
« Reply #13 on: October 16, 2011, 09:21:24 AM » |
mustard will help on burns of all type. Had a friend burn himself on the muffler of a chain saw, but mustard on the burn and no blister and it cooled the burn right down
hotglue #43
« Reply #14 on: October 16, 2011, 01:17:51 PM » |
If ya smash a finger.... pour a little turpinetine on it and it will immediately take away the throb...it's true.
 blue=3 times green=at least 4 times When they are all 'green'.. I'll stop counting.
FryeVRCCDS0067
« Reply #15 on: October 16, 2011, 04:31:25 PM » |
Brake cleaners, chlorinated or not, contain nasty solvents, almost all of which are carcinogenic. Some of these can pass through healthy skin and target various organs. This is normally a concern with prolonged exposure, but in this case is being sprayed on already damaged skin. I'm sorry, but I wouldn't recommend it. Try some of that sissy Aloe stuff instead.  Troof. OK, I know I'm a dumb A$$ but you're killing me here. Troof?
"Extremism in the defense of liberty is no vice. And... moderation in the pursuit of justice is no virtue.'' -- Barry Goldwater, Acceptance Speech at the Republican Convention; 1964
6jugzz
LUV2RIDE...buy safety chrome
Rock hill,SC
« Reply #16 on: October 16, 2011, 05:33:26 PM » |
If u ever want to eat a carp, boil in water,cedar chips and an old army boot. When tender to the touch,throw it away and eat the boot.
FryeVRCCDS0067
« Reply #17 on: October 16, 2011, 06:42:21 PM » |
If u ever want to eat a carp, boil in water,cedar chips and an old army boot. When tender to the touch,throw it away and eat the boot.  A fresh killed carp, preferably caught in or shot with a bow from cold water. Filleted, skinned and the "strip of red meat" cut out can be damn good. Specially when it's grilled over an open fire on a river bank. The looks on the faces of the city people in "rent a canoes" when your son comes across the creek with a huge carp spouting gouts of blood and a bow and fish arrows is priceless too.  Buttt...., WTH is Troof?
« Last Edit: October 16, 2011, 06:44:35 PM by FryeVRCCDS0067 »
RP#62
« Reply #18 on: October 16, 2011, 06:44:11 PM » |
All this reminds me of one of my father in law's old sayings: If you eat a live toad for breakfast, nothing worse will happen to you all day.
-RP
Fathertime
« Reply #19 on: October 16, 2011, 09:46:15 PM » |
Troof: What the dentist yanks outta yourn jaw iffen you'all dont brush your teeth every week!
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #20 on: October 17, 2011, 02:04:54 AM » |
MacDragon
Middleton, Mass.
« Reply #21 on: October 17, 2011, 05:06:30 AM » |
The troof... and nuthin but the troof...
