January 28, 2026, 03:23:52 PM *
Author Topic: Lowered 11.5 shocks and Car Tire - Will it work?  (Read 3221 times)
RUDE DOG - Steelers
New Jersey - VRCC # 3966
« on: May 02, 2009, 11:20:00 AM »
I just installed my new Progressive 430 11.5 inch shocks and she sits nice and low. Will be slipping the forks also.  My next step is I want to install a Yokohama A048 205/55 Darkside tire.  I assume I will have to do the nut cage mod and maybe the fender washer thing.  Will this setup work with the car tire?  I have an '03 standard and ride mostly solo.  Pics are appreaciated.
Buddy
« Reply #1 on: May 02, 2009, 12:57:33 PM »
Same set up here for about 3 yr. works well. I ride solo about 200#
RUDE DOG - Steelers
« Reply #2 on: May 02, 2009, 01:29:34 PM »
Do you have the A048 Yoko?  Can you post a pic?  Did you slip the forks also?  What mods did you do for the tire?  Im 180lbs. Thanks.
skull6
« Reply #3 on: May 03, 2009, 04:57:03 AM »
I have stock shocks and 55 car tire Lowering makes kickstand bracket more likley to hit on speed bump or going into a shed or trailer with a ramp. I mangled my kickstand cross member hitting a bump. I was guilty of going to fast on a bumpy road.
RUDE DOG - Steelers
« Reply #4 on: May 03, 2009, 03:34:04 PM »
Only two people have used a car tire and shorter shocks????????????????  Need more feedback before I spend the money.
96valk
Oregon
« Reply #5 on: May 09, 2009, 11:18:10 PM »
have at least 10,000 miles with car tire, short shocks, 5/8 slipped tubes. have rode single and two up with full bags and luggage.  Need to bend kickstand to lean the bike over enough on a sloped parking spot
RUDE DOG - Steelers
« Reply #6 on: May 10, 2009, 01:13:12 AM »
I got my 430 11.5 inchers on and slipped the forks 5/8 also.  Car tire is on the way.  What length shock do you have?
96valk
Oregon
« Reply #7 on: May 10, 2009, 11:21:57 PM »
I think they are the same lenth as yours.  got them in Sturgis several years ago and they were about 1 - 1  1/2 inces shorter than stock.  Used to ride two up with full bags my teenage son and both of our duffels on behind. nut cages taken care of.  No problems
RUDE DOG - Steelers
« Reply #8 on: May 11, 2009, 02:47:32 PM »
Just got my Yokohama A048 205/55 tire today. Man it looks really big.  Will be working on the Darkside change over.  How much grease are we supposed to put on the splines?  Light coating or heavy?
Old Geezer Richard
San Antonio , Tx
« Reply #9 on: May 11, 2009, 11:15:43 PM »
Stealers , I raised my shocks all the way up 4 th setting on my std with the  55 car tire and she handles better than before when set at the 2nd setting  WITH NO PROBLEMS AT ALL remember to be safe you will have to do the nut cage mod .... I know a few people who adjusted their stock shocks all the up and they said it handled better so I did it .... my old 98 stock shocks are going to be replaced with some progressive HD 440's  13 " real soon  along with the prog front springs .... riding two up with stuff and pulling a trailer I need all the help I can get ..... Thanks Old Geezer Richard
« Last Edit: May 11, 2009, 11:18:25 PM by OLD GEEZER » Logged
96valk
Oregon
« Reply #10 on: May 12, 2009, 06:56:43 PM »
good luck with the progresive front springs I had them installed and they are bouncy at below 55 mph the dealer wouldn't stand behind them Progresive no help either. I am replacing with another pair of forks
