January 28, 2026, 11:03:56 PM *
Author Topic: Finally Found the Elusive Buzzing Noise!!!!!!!!!!!!!!  (Read 3554 times)
DDCD
« on: May 02, 2009, 12:48:54 PM »
I am happy to say that after a lot of looking for the buzzing noise at apprx. 2000-2300 RPM, I finally fouind it.
I checked the notorius buzz bolt and most of the other common sounds.
I would have been willing to bet it was coming from the frt. of the engine area, but no, it was coming from the Kuryakn Trans cover [r/side].
They have been on the bike since '98 and only recently started making me crazy each time I accelerated in this rpm range.
I pulled it off and looked at the mounting bolts. They had fiber insulating washers on them, and 2 of the 3 washers were deteriorated and split in half. I replaced the washers [courtesy of Home Depot] and now it's fine.
Hope this helps others who might have this accessory on their bike
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #1 on: May 03, 2009, 02:29:11 PM »
Man...  Hope yer right.  I've had this going on since last fall, and it's makin me nutz  uglystupid2
No matter what gear, same RPM (2100 - 2300), I get this metalic noise...  Thought it was clutch, bearings, something in the engine...  Checked the buzz bolt, NOTHING!!!
I had to stop in to work, but I'm gonna check that when I get home.
I'll report back.
Black Dog
Don't you know...
Earl in Pensacola
« Reply #2 on: May 03, 2009, 03:37:14 PM »
Some months back I too was having the same buzzing. I finally bought and replaced the infamous bolt all to no avial.  I too found the after placing insulation gaskets (rubber ones) inside and outside on the tranny mounting bolts all the buzzing stopped.  I'm sorry I didn't double back and post it.  Actually, I meant too, but wasn't sure that was the cure and decided to ride it for a while, THEN I forgot.
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #3 on: June 24, 2009, 07:33:25 PM »
I think I may be hearing the same buzz.  Before you found the noise did the covers appears to be tight?  Mine seem tight.  If I tap them I do not get an rattle.
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
Ghillie
Garland, TX
« Reply #4 on: June 24, 2009, 07:51:31 PM »
I am getting a similar noise on m 98. First tell me what the infamous buzz bolt is. Then I will pull the tranny cover bolts.
When the people fear government, there is tyranny. When government fears the people, there is liberty.
« Reply #5 on: June 24, 2009, 08:24:17 PM »
Look here....
http://www.valkyrieriders.com/shoptalk/buzz.htm
Hay  Cool
greggh
OMAHA NE
« Reply #6 on: June 24, 2009, 09:13:02 PM »
I have what I think is the same noise happening with my 98.
Sounds like it is comming from the font end.
You say the washers for the bolt on the Kury trans cover?
I assume this washer goes to the inside portion of the bolt?
How about putting some kind of insulator on the inside of the trans cover to also help reduce noise, has anyone done this yet?
fordmano
San Jose, CA.
« Reply #7 on: June 25, 2009, 02:25:57 AM »
I just noticed a buzz after I installed my chrome neck cover in front of the Tank.
I have one of the show chrome covers that is a 2 piece setup, seemed to work ok when I first installed but after  a remove and replace to check something under the tank out it now buzzs from about 2500rpm up to about 3200rpm. Verified by just putting my hand on it while riding and the buzz goes away. I need to take it off again and put some type of buffering material between the 2 pieces.
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
Spirited-6
Nicholasville, Ky.
« Reply #8 on: June 25, 2009, 06:22:00 AM »
I have the same 2 piece setup, CRANK it down a notch and should solve buz.  Wink
Spirited-6
blkvlk777
« Reply #9 on: June 25, 2009, 08:47:01 AM »
I spent about 1 summer looking for a buzz that would happen at a certain RPM range.  It took me forever to pin point it.   It ended up being the add-on Left side Chrome Engine hanger piece.  It went off like a tuning fork.  I know the frustration - I damn near tore the bike apart before I found it.  Keep looking hopefully you find it.
Gangman036
Terre Haute, IN
« Reply #10 on: June 25, 2009, 08:22:48 PM »
I remember reading here that you could attach some self sticking (glue on one side) rubber foam strips to the back side of the tranny cover to kill the buzzing too.
REDTIM
« Reply #11 on: June 27, 2009, 09:06:18 PM »
Mine did that from the very start after installing took them off and allpied this stuff called Dynamat and I never had a problem again.
« Reply #12 on: June 28, 2009, 01:28:51 PM »
did the buzzing noise go away as soon as you let off the throttle
I have been tryin to pin down a noise that sounds like noise in the headphones when on the throttle.  Of course I am not wearing headphones but its what it sound like and when I let off the throttle it goes away
TIA
