Michael K (Az.)
Glendale, AZ
« on: October 24, 2011, 11:56:11 AM » |
Are they still out there and available? Thanks, Michael K
« Reply #1 on: October 24, 2011, 01:16:32 PM » |
Yes.......
If it says it will fit a VTX, it will fit the Valk.
Last I knew, HDL stocked them.
Spirited-6
« Reply #2 on: October 24, 2011, 01:27:24 PM » |
Yes.......
Will not, unless you do a little grinding on "foot" of kick stand. You need to grind off a little to be able to slide on and set screw to tighten. You need to paint spots with silver paint to stop rust from forming Been there.
Spirited-6
joefromperry
« Reply #3 on: October 24, 2011, 09:11:13 PM » |
Last I knew, Mike Terry (Valkyrie Bling) had a few. I got one from him at InZane.
2000 Honda Valkyrie Interstate Silver/Blue 2002 Honda Shadow ACE Deluxe 1972 Honda CL350K4 Scrambler 2008 Ural Patrol 1987 Honda Rebel 450
Thunderbolt
« Reply #4 on: October 25, 2011, 12:35:47 PM » |
I know you don't have flats anymore, but if it is extended higher, the bike will tend to fall over to the right easier. That being said, I put one on Iris's bike, it made it easier to get off the stand. I found a Valk part for hers.
Michael K (Az.)
Glendale, AZ
« Reply #5 on: October 25, 2011, 02:47:15 PM » |
Yeah, I got those flat tires out of my system when I left Fl.!  I'm thinkin about going with a 'taxi' CT next time and for some reason, my bike seems to feel like it leans pretty deep on the stand now and the taxi is about 1" taller, soooo - - - - - - -!
« Reply #6 on: October 25, 2011, 09:46:17 PM » |
Yes.......
Will not, unless you do a little grinding on "foot" of kick stand. You need to grind off a little to be able to slide on and set screw to tighten. You need to paint spots with silver paint to stop rust from forming Been there. Spirited-6, I really don't now how to respond to your response. The will not, you is full of Umpa. The same grindings on the Valkyrie have to be done on the VTX & vicea/versa. I've put mucho many of these on for our VRCC members, and every damn one of them had to be ground on. And I'm referring to the original ones Rivco put out, and also the later ones for the VTX. They are the same damn part, just have a different part #. I used to help Rich install these things at various Rallies.
Spirited-6
« Reply #7 on: October 26, 2011, 06:01:54 AM » |
Yes.......
Will not, unless you do a little grinding on "foot" of kick stand. You need to grind off a little to be able to slide on and set screw to tighten. You need to paint spots with silver paint to stop rust from forming Been there. Spirited-6, I really don't now how to respond to your response. The will not, you is full of Umpa. The same grindings on the Valkyrie have to be done on the VTX & vicea/versa. I've put mucho many of these on for our VRCC members, and every damn one of them had to be ground on. And I'm referring to the original ones Rivco put out, and also the later ones for the VTX. They are the same damn part, just have a different part #. I used to help Rich install these things at various Rallies. RJ, you did not read the "UNLESS". They are not a plug & play. They will fit after grinding.  The I bought for the VTX would not slide on far enought until grinding a little off.
« Last Edit: October 26, 2011, 06:03:55 AM by Spirited-6 »
Spirited-6
« Reply #8 on: October 26, 2011, 08:13:51 AM » |
You are just like my kids, ya want to argue about any and all answers/responses.
NO, it was a plug and play on Rich's bike, but those kick stands were not all created equal..
He deicded it was not worth the $$$$$ to change the mold so, yupper, you is correct, they are not Plug & Play.
Now, would ya please let sleeping dogs lay? Tanx.
I'm done talkin about it.
