fubar606
« on: October 24, 2011, 03:41:37 PM » |
dose anybody know if there is a repair kit for a 440 progressive shock. or dose any one have one they would sell ?
life is sexually transmitted and always fatal
« Reply #1 on: October 24, 2011, 04:43:50 PM » |
Have ya talked to Progressive?
That's where I would start.
blackvalk
« Reply #2 on: October 24, 2011, 04:48:05 PM » |
I think the 440's have a lifetime warrenty
fubar606
« Reply #3 on: October 24, 2011, 07:20:48 PM » |
haven't talked to progressive yet . that's next
Bob E.
« Reply #4 on: October 25, 2011, 07:41:33 AM » |
If you still have the receipt, they are guaranteed. I've sent mine back once when they both leaked. And now it looks like I'll have to send the left one back because it is leaking again. Pretty crappy life for $450+ shocks.
fubar606
« Reply #5 on: October 25, 2011, 08:43:02 AM » |
just talked to progressive if i send them in they will fix and then i am original owner. about $200 to fix. doable
« Reply #6 on: October 25, 2011, 10:00:16 AM » |
Is it just me or is there a crazy high percentage of them progressive rear shocks that leak and have to be repaired. I have had a lot of bikes and never had a shock leak, never had a progressive rear shock either though. Just seems there should be something out there that doesnt do that as much.
fordmano
San Jose, CA.
« Reply #7 on: October 26, 2011, 11:57:33 PM » |
Been having trouble with my 416's and they are going to Progressive this week for a rebuild and they have not said anything about any cost to me.
Turns out one of them is bad/wrong from new. They bottomed out easy at any air pressure and then when I removed the air lines sounds like one side is ok and the other is holding air like a one way valve when I let the air out of the lines seemd about proper amount of air escaped. Then when I pulled the line off of one side it almost exploded in my hand like it had a one way check vale in the line the pressure was not released when the air inlet T was opened up... so back they go worked via email with thier tech support and he had me setup with an RMA# easy as possible to work with.
 83GS550 93XR650L TARD! 97WR250 99ValkyrieI/S Tri-tone 01YZ125(x2) 05DRZ-125
tmfp
« Reply #8 on: October 27, 2011, 10:02:36 AM » |
For owners in Europe, Hagon, a long established Brit manufacturer, have very good quality replacement shocks starting at less than $200 per pair, to over $500 for fully adjustable nitro stainless steel. http://www.hagon-shocks.co.uk/catalog/config.aspx?TypeID=T
« Last Edit: October 28, 2011, 12:57:00 AM by tmfp »
The Anvil
« Reply #9 on: October 27, 2011, 04:26:10 PM » |
If you still have the receipt, they are guaranteed. I've sent mine back once when they both leaked. And now it looks like I'll have to send the left one back because it is leaking again. Pretty crappy life for $450+ shocks.  450? I've spent more than double that for ONE SHOCK. 450 really isn't very expensive at all relatively speaking.
Boxer rebellion, the Holy Child. They all pay their rent. But none together can testify to the rhythm of a road well bent. Saddles and zip codes, passports and gates, the Jones' keep. In August the water is trickling, in April it's furious deep.
