February 03, 2026, 03:35:24 PM *
Author Topic: Need help with installing front fender extension.  (Read 1331 times)
Dave Weaver
Seymour, IN
« on: October 24, 2011, 04:53:20 PM »
I purchased a used front fender extension over the weekend and need advice on mounting it.  Is there a template one can use to drill the holes with or did the extension come with instruction as to where to drill the holes?  I just want to be sure and drill the holes in the proper place.  Thanks
Do unto others as you would have them do unto you.
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #1 on: October 24, 2011, 04:57:44 PM »
Put mine on years ago and don't recall any instructions.
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
« Reply #2 on: October 24, 2011, 06:24:18 PM »
Get it where you want it ...mark and drill....Be sure to put a 2x4 or something like between the tire and the drill bit .
« Reply #3 on: October 24, 2011, 06:24:48 PM »
Is it the Honda Line or the Show Chrome extension?  I'm not 100% sure, but I think that they are identical.
Here's the instructions for the Show Chrome.....
http://www.cruiseraccessoriesonline.com/pdf/1-326.pdf
« Reply #4 on: October 24, 2011, 06:41:29 PM »
Got mine used from my brother. coolsmiley Used small (1 inch) c-clampps to hold it to fender. Cool Drilled thru the existing holes in the extension with a wood block on inside of fender. coolsmiley No problem what so ever. cooldude RIDE SAFE.
