August 21, 2025, 10:38:31 PM *
Author Topic: CA desmog debrief  (Read 1091 times)
Mulepick
« on: October 26, 2011, 04:24:47 PM »
CA smog debrief:
So.  On the CA model you get to not only plug all the plugs with, say, a "shiny" redeye desmog kit and remove all the hard piping, PAIR, reed valve assys, etc, but you also get rid of the purge control valve, the carb air vent control valve, the associated piping and the canister.  In addition to the kit you'll need six 3/16 vacuum caps for each carb, a routing plan for the carb breather hoses (I bought a longer tubes and a tee, attached them to tee and stuck tee in one of the holes that exist for tubes #14), AND a cap for the nipple on carb #3.  I highlight this because I haven't seen it has part of any other writeup.  The little nipple on the end of the vent control valve goes to a nipple above the float bowl on carb 3.  See photo.  This takes a smaller cap, same size as intake manifolds.  Red eye sells them in three packs with "finger friendly" metal stays.  >I have no relationship to red eye aside fm being a customer<
Of course, if you're swapping to a non-vac petcock as I did you get to throw away another vac hose and add another plug to #6 intake.
Looks like you'll have to go here:
http://valkyrie-owners.com/SMFORUM/index.php/topic,10309.0.html
to see diagram/photo.
Bob
Mr Bojangles
Bonham Texas
« Reply #1 on: October 31, 2011, 07:19:33 AM »
Thanks! I needed that! I have a CA model. (tourer)
                                              BoJangles
Still on the right side of dirt, it is a good day!
