March 24, 2026, 08:32:01 PM *
Author Topic: 10,000 mile review of the Interstate  (Read 1600 times)
lucky_1_chris
Arlington, TX
« on: October 27, 2011, 07:28:30 PM »
Lovin' it.
Few minor issues here and there, has its quirks... I'd buy it again in a heartbeat. I will be on this bike til it gives up.
1999 Valkyrie Interstate
sugerbear
wentzville mo
« Reply #1 on: October 27, 2011, 07:51:36 PM »
or, you give out Grin
these things last a looooong time. cooldude
Valkpilot
What does the data say?
Corinth, Texas
« Reply #2 on: October 27, 2011, 08:05:43 PM »
Chris is a youngster.  He'll outlast most of us.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
lucky_1_chris
Arlington, TX
« Reply #3 on: October 27, 2011, 09:08:20 PM »
I can only hope... cooldude
Exit to add: If St. Louis keeps tying it up with one strike left I ain't outlasting anybody...
« Last Edit: October 27, 2011, 09:25:08 PM by lucky_1_chris » Logged
sugerbear
wentzville mo
« Reply #4 on: October 28, 2011, 07:15:03 AM »
"they just won't go away"
favorite quote from the game last night.
i don't care who won last night THAT was a fun game cooldude
would like to see the cards win, but, would be nice to see texas win their first Smiley
« Reply #5 on: October 28, 2011, 09:42:27 AM »
The 9th 10th and the 11th innings were fer sure very exciting. 2funny Every time i thought the Cards were toast they kept pulling stuff outin their backside. Roll Eyes Tonights game is either gonna be a barn burner or a blow out. crazy2 The one thing it will not be is boring. Cool At least I M H O. Go Cards. RIDE SAFE.
F6Mark
2000 Red/Blk Tourer
College Park, MD
« Reply #6 on: October 28, 2011, 05:42:22 PM »
Lovin' it.
has its quirks...
I'm trying to think of my bikes quirks- not sure it has any.  Starts easy, runs consistently powerful (or is it powerful consistently), uses no oil, decent handling.
What quirks would you be referring to?  Anything in particular?
VRCC 6020
lucky_1_chris
Arlington, TX
« Reply #7 on: October 29, 2011, 12:01:43 AM »
Lovin' it.
has its quirks...
Very high speed, and very low speed wobble. The low speed wobble is only when turning. I can take my hands off the bars at all speeds under 110 and no wobble. With the fairing and front wheel off, the trees stay where I put them. Don't think it's the stem bearings. Most likely tire wear at low speed, and air over the fairing at high speed. I'm gonna call it normal based on what I've read here. The rear avon makes noise in turns. Apparently this is a common issue, and it has a name..."dragon growl"...I'll try a different rear at my next tire change, and if it comes back I'm going DS. Trunk and fairing rattles (mostly fixed). Front end dive when braking fixed with progressive springs and new fork oil, but it's a bit on the stiff side now. My fork legs have a bunch (a lot. many. maybe hundreds) of little scratches on them from where the fork seal rests to where the lowest point on the leg the seal can reach. Looks like the previous 2 owners neglected the maintenance on the forks. They don't leak anything to worry about, but I'll replace them when the stem bearings go. 3 sets of shock bushings in 8k. One that were on the bike when I bought it, 2nd were polyurethane, 3rd were stock. I'm 270 lbs., but still... VTX used the same bushings and didn't go through 3 sets in 30k. Valkyrie is heavier, but damn... I've got 440's on now, so we'll see. Might just be my fat ass... 2funny U-joint was causing some vibration. It had VERY little play, but play it had... Vibes went away when I swapped it out. My wife's car gets better gas mileage... 2funny. It will NOT start without a little throttle. It'll start down to the low 40's without the choke, but it HAS to have a little throttle to start at any temp. By little I mean just enough throttle to feel tension. Not much. I could crank it 'til the battery dies unless I give it a very little bit. Front calipers would rattle going over the slightest little bump, but new pad springs solved this problem. I should say the pads were rattling, not the calipers, but whatever.
When I say quirks, those are what I'm talking about. Minor for sure.
It runs flawlessly, and hasn't used/burned/leaked a drop of any fluid except the tiniest little bit of fork oil since I've had it. It handles exceptionally well at slow slow speeds for a bike of its size. I can go lock to lock in a parking lot with ease. Once I'm in 5th, I can stay in 5th from 30 mph on up and barely feel any vibration unless I'm climbing a hill. In the mountains/twisties I can leave it in 3rd from almost barely rolling up to 80ish and still push myself back in the seat when twisting the throttle. I'm NEVER in the wrong gear. I thought it was a little piggish when I first got it, but now I can make this bike do anything I want it to do at pretty much any speed I please. It is SMOOTH... After being on loud, vibey bikes for nearly the last decade, and even though I'm thoroughly used to the Valk, I still find myself twisting the throttle a little bit sometimes at stoplights to make sure it's still running. I ride with guys that ride a V2k, Vmax, RS Warrior, and VTX's of both the 13 and 18 variety, and I'll pull on all but the V2k and the Vmax. I can't say that it does any one thing exceptionally well, but it does VERY well at EVERYTHING I ask it to do. This bike is my main source of transportation, and I couldn't ask for a better bike for that purpose. I love this bike.
« Last Edit: October 29, 2011, 12:10:12 AM by lucky_1_chris » Logged
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #8 on: October 29, 2011, 10:09:40 AM »
[It runs flawlessly, and hasn't used/burned/leaked a drop of any fluid except the tiniest little bit of fork oil since I've had it. It handles exceptionally well at slow slow speeds for a bike of its size. I can go lock to lock in a parking lot with ease. Once I'm in 5th, I can stay in 5th from 30 mph on up and barely feel any vibration unless I'm climbing a hill. In the mountains/twisties I can leave it in 3rd from almost barely rolling up to 80ish and still push myself back in the seat when twisting the throttle. I'm NEVER in the wrong gear. I thought it was a little piggish when I first got it, but now I can make this bike do anything I want it to do at pretty much any speed I please. It is SMOOTH... After being on loud, vibey bikes for nearly the last decade, and even though I'm thoroughly used to the Valk, I still find myself twisting the throttle a little bit sometimes at stoplights to make sure it's still running. I ride with guys that ride a V2k, Vmax, RS Warrior, and VTX's of both the 13 and 18 variety, and I'll pull on all but the V2k and the Vmax. I can't say that it does any one thing exceptionally well, but it does VERY well at EVERYTHING I ask it to do. This bike is my main source of transportation, and I couldn't ask for a better bike for that purpose. I love this bike. /quote]
Wow Lucky, that was beautiful!  Cry a tear in my eye cooldude
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
DarkMeister
« Reply #9 on: October 29, 2011, 10:29:56 AM »
Couple of major issues with my Interstate. Lousy in snow, for one. Tires suck, also too as well. Also.
Checked the tire pressure a few days ago (April 2011) and they were close to 40lbs. Checked again yesterday and they were under 30lbs each! Very poor performance.  tickedoff
